How Can A Be Calculated for Uniform Electric Field in a Spherical Shell?
In summary, the problem involves a non-conducting spherical shell with a positive volume density and a small ball of charge located at the center. The goal is to find the value of A for which the electric field within the shell is uniform. Using Gauss' Law, the electric field can be related to the volume and charge density, but it is necessary to integrate over the volume of the shell. This leads to a complicated expression involving the natural logarithm and the volume and radius of the shell. Further steps are needed to solve for A, and it may also be possible to use Gauss' Law in a different way to simplify the solution.
paralian
(Note: Don't worry about significant digits. I just want to be able to do the question and will worry about significant digits on the exam.)
In the figure below, a non-conducting spherical shell of inner radius a=2.00cm and outer radius b=2.40cm has (within its thickness) a positive volume density [tex]\rho[/tex]=A/r, where A is a constant and r is the distance from the centre of the shell. In addition, a small ball of charge q=45.0 fC is located at the centre.
What value should A have if the electric field in the shell (a[tex]\leq[/tex]r[tex]\leq[/tex]b) is to be uniform?
(See attached file for the picture. sorry it isn't very good. That's a "q" beside the +ve charge in the middle.)
Charge density : [tex]\rho= \frac{dq}{dV}[/tex]
Volume : [tex]V = 4\pi r^3[/tex]
Electric field : [tex]E = \frac{1}{4\pi \epsilon} \int \frac{dq}{r^2}[/tex]
E at a distance r anywhere within [a, b] is constant.
E is caused by the point charge and distribution of charges in the volume.
[tex]E_{net}[/tex] is constant, therefore
[tex]E_{charge}=-E_{volume}[/tex]
[tex] \frac{1}{4\pi \epsilon} \int \frac{dq_{charge}}{r_{charge}^2} = - \frac{1}{4\pi \epsilon} \int \frac{dq_{volume}}{r_{volume}^2}[/tex]
the E for a point charge doesn't need to have an integral, because it works out that way.
[tex] \frac{q_{charge}}{r^2} = - \int \frac{dq_{volume}}{r_{volume}^2}[/tex]
Charge density : [tex]\rho= \frac{A}{r} = \frac{dq}{dV}[/tex]
[tex]dq = \frac{A}{r} dV[/tex]
[tex] \frac{q_{charge}}{r^2} = - \int \frac{A dV}{r^3}[/tex]
dV is related to r because [tex]V = \frac{4}{3} \pi (r^3 - a^3)[/tex]
then [tex]r^3 = \frac{3V + 4 \pi a^3}{4 \pi}[/tex]
[tex] \frac{q_{charge}}{r^2} = - \int \frac{4 \pi A dV}{3V + 4 \pi a^3}[/tex]
[tex] \frac{q_{charge}}{r^2} = - 4 \pi A \int \frac{dV}{3V + 4 \pi a^3}[/tex]
[tex] \frac{q_{charge}}{r^2} = - \frac{4 \pi A}{3} ln (3V + 4 \pi a^3)[/tex]
I don't know what to do after this, and I don't know what to do. I don't know if I messed up something.
This may be supposed to be done with Gauss' Law, but I couldn't figure out what to do with that.
Gauss' Law : [tex]\Phi = \oint E da[/tex] (In this case since E and a are in the same direction, the dot product just became E da)
\Phi = \oint E da = \int_a^b E 4 \pi r^2 dr = \frac{q}{\epsilon} I don't know what to do with this either. Can someone help me?
The electric flux through a closed surface is equal to the charge enclosed by the surface divided by the permittivity of free space.
Based on the given information, the value of A can be determined by using Gauss' Law. Since the electric field is constant within the shell, we can use a Gaussian surface in the shape of a sphere with radius r, where a≤r≤b. The electric flux through this surface is equal to the charge enclosed by the surface divided by the permittivity of free space.
Therefore, we can write the following equation:
Φ = EA = qenc/ε0
Where qenc is the enclosed charge within the Gaussian surface. In this case, the only charge enclosed is the small ball of charge q at the center.
qenc = q = 45.0 fC = 45.0 x 10^-15 C
Substituting this into the equation, we get:
Φ = EA = (45.0 x 10^-15 C)/ε0
Now, we know that the electric field E is constant within the shell, so we can write:
E = qenc/(4πε0r^2)
Substituting this into the previous equation, we get:
Φ = (qenc/(4πε0r^2))A = (45.0 x 10^-15 C)/ε0
Solving for A, we get:
A = (45.0 x 10^-15 C)4πε0/(ε0r^2) = 45.0 x 10^-15 C/(4πε0r^2)
Since r is the distance from the center of the shell, we can write:
r = (a+b)/2 = (2.00cm + 2.40cm)/2 = 2.20cm
Substituting this into the equation for A, we get:
A = 45.0 x 10^-15 C/(4πε0(2.20cm)^2)
Simplifying, we get:
A = 1.45 x 10^-12 C/m^2
Therefore, the value of A should be 1.45 x 10^-12 C/m^2 for the electric field to be uniform within the shell.
Related to How Can A Be Calculated for Uniform Electric Field in a Spherical Shell?
1. What is an electric charge in a shell?
An electric charge in a shell refers to the distribution of electric charge on the surface of a spherical object, such as a conducting shell or a charged particle. The electric charge on the surface of the shell creates an electric field both inside and outside of the shell, affecting the behavior of nearby charged particles.
2. How does an electric charge in a shell differ from an electric charge in a solid object?
In a solid object, the electric charge is distributed throughout the volume of the object. However, in a shell, the electric charge is only present on the surface. This difference in distribution affects the electric field and potential inside and outside of the object.
3. Can an object have both positive and negative electric charge in a shell?
Yes, an object can have both positive and negative electric charge on its surface if the total charge is zero. This is known as a neutral object, and the positive and negative charges cancel each other out, resulting in no net electric charge.
4. How does the thickness of a shell affect its electric charge?
The thickness of a shell does not affect its electric charge, as long as the total charge remains the same. The charge is distributed on the surface of the shell, so the thickness does not play a role in determining the amount of charge present.
5. What are some practical applications of electric charge in a shell?
Electric charge in a shell has various practical applications, such as in electrostatic shielding, where a conducting shell is used to protect an object from external electric fields. It is also used in spherical capacitors, where a charged shell acts as one of the plates. Additionally, the distribution of charge on a spherical object can be used to determine the mass and charge of particles in experiments.
