Electric Field at center of triangle
To determine the electric field strength at the center of an equilateral triangle formed by three rods, two charged positively and one negatively, it's essential to calculate the electric field from each rod individually. The electric field formula E = kq/r^2 applies to point charges, but since the charge is distributed along the rods, a linear charge distribution approach is necessary. By integrating the contributions from infinitesimal charge elements along each rod, the total electric field can be found by vectorially summing the fields from all three rods. The symmetry of the setup will influence how the fields interact, particularly with the two positively charged rods. The final electric field strength is obtained by carefully considering the direction and magnitude of each component.
ashkash
Three 18.0cm long rods form an equilateral triangle. Two of the rods are charged to + 13.0nC , the third to - 13.0nC .
What is the electric field strength at the center of the triangle?
I have spent a lot of time on this problem and have not been able to get anywhere. Please help.
Try finding the field exerted by one rod at at time, and then add it all together vectorally.
Wouldnt two of them cancel out as they have the same charge?
They do have the same charge, but not opposite directions. Only part of them will add together. Each rod will have it's own electric field exerted at the center point of the triangle. If you add each of those electric field vectors up, you should get the right answer, but be sure to teart them all as a vector.
I am still having a hard time with this. What would be the formula to use for calculating the electric field, E=kq/r^2? And what would I use as r? Thanks for the help.
This formula for electric field is due to a point charge at distance r from it, but in yout problem the charge is distributed over the rod or it is a linear charge distribution.
First find out the field due to charge on one rod by taking an infinitely small charge on a small element of the rod, have components along and perpendicular directions and then by integrating find the field due to the whole rod. Then the vector sum of the three fields will give the required field strenght.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
