Electric Field at Midpoint of Equilateral Triangle
To find the electric field at the midpoint between charges q1 and q2 in an equilateral triangle configuration, the distance used for calculations should be half of the total distance between the two charges, which is 1.475 cm. The electric field contributions from q1 and q2 must be calculated using the equation E = k q/r^2, considering their respective x and y components. The charge q3, being negative, will also influence the electric field at the midpoint, with its distance to the midpoint being perpendicular to the line joining q1 and q2. The calculations may yield unexpectedly large values, prompting a review of the distance and charge values used. Accurate component analysis and careful consideration of angles are essential for correct results.
Brit412
The figure shows a system consisting of three charges, q1=+5.0uC, q2=+5.0uC and
q3=-5.0uC, at the vertices of an equilateral triangle (with q2 at the top point of the triangle).
Find the magnitude of the electric field at a point halfway between the charges q1 and q2.
distance= 2.95cm
i know an equation is E= k q/r^2
So since it wanted to know the halfway point, I divided the distance between the points in half and used it as r. And I figured that the charges have an x and y component but what angles do I use??
Triangle is equilateral. So the sides are equal. Find the distance between the charge q3 and the mid point of charge q1 and q2. The line joining q3 and mid point is perpendicular to the line joining q1 and q2.
I got a pretty big number (a number times 10^8). That seems too big??
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
