Electric Field charge calculation
The discussion revolves around calculating the electric force between two protons separated by a distance of 3.80 x 10^-10 m, using the formula F = k_e * (q1 * q2) / r^2. Participants confirm the charge of a proton as +1.6021917 x 10^-19 and discuss the final calculated force, questioning the correctness of their results. Additionally, there is a speculative conversation about whether 15 pounds of electrons could support the mass of the Earth, highlighting the strength of electromagnetic forces compared to gravity. Challenges regarding the containment of such a charge and the implications of excess electrons are also explored. The conversation emphasizes the significant difference in strength between electromagnetic and gravitational forces in theoretical scenarios.
Brad_1234
Hi
This is a homework question, but I am trying to see if I've got the format correct. Two protons are separated by 3.80 x 10-10m. Find the electric force exerted by one proton on the other
...... |q1||q2|
So I've got Fe =.. ke ------------
...... r^2
Im told the proton charge is +1.6021917 x 10-19
so...... 2.5667E-38
...ke * .. -------------
...... 1.444 E-19
then... ke * 1.7775 E -19
then 1.5979 E-9 as the final answer?
Is there some way to write equations and allow whitespace?
Brad_1234 said:
Hi
...... |q1||q2|
...... r^2
so...... 2.5667E-38
...... 1.444 E-19
F = \frac{2.5667E-19}{1.444E-19}
Okay I wrote this by typing this: [ itex ] F = \frac{2.5667E-19}{1.444E-19} [ /itex ] (take out the spaces in the tags with the square brackets.)
F_{total} = K_e \frac{Q_1 Q_2}{r^2}
This was written with this:[ tex ] F_{total} = K_e \frac{Q_1 Q_2}{r^2} [ /tex ] (again take out the spaces)
Hey that's too cool F_{total} = K_e \frac{q_1 q_2}{r^2}
its not working on preview, anyone know if the result is correct?
also, would 15 pounds of electrons have enough field energy to support the mass of the earth? It calculates out to be many times more, but if that's the case? batteries can still be improved to store more energy
This is my first Physics for electricity/Magnetism course
Without doing any equations, I'm pretty sure 15 pounds of electrons would be more than enough to support the Earth. What you mean by support the Earth though, I'm not sure. The electromagnetic force is some 38 orders of magnitude (or thereabouts) stronger than gravity. You would have some problems though:
-How do you get 15 pounds of electrons without any protons
-Given that the electromagnetic force is so strong, how do you contain them, since they will want to repulse each other.
- The overall net charge on the Earth (I'm assuming) is probably very close to zero, so the net force on the Earth is going to be very small.
But yeah, the electromagnetic force is much, much stronger than gravity, its just that in everyday life, almost everything has the same number of positive and negative charges, so it cancels out.
One of our questions was 2 people standing at arms length, each has 1% excess in their body weight of electrons, would there be enough force between them to lift the mass of the earth? or something like that.
I got the result down to Newtons, starting with each person 150lbs, oops I calculated 15lbs but that's 10%? 1.5lbs of excess electrons...
And I figured the distance was 2 meters. taking the weight of electrons, dividing in 15 pounds, got some number then multiplied to get charge then applied the F_e equation with the distance as 2m and it came out to 3.23 E33 Newtons of force or 3.29 E32 kG of force and the Earth weights a mere 6 E24 kG ?
Yes, how to contain the charge. don't know... maybe need particles smaller than an electron that have even stronger bonds to make a container. Arent radioactive materials extra heavy because they have too many electrons? What would it take to order the electrons back to the nucleus?
