Electric field due to a FINITE cylinder of charge - Tricky binomial expansion
The discussion revolves around calculating the electric field at an axial point of a thin, uniformly charged cylinder. The cylinder has a specified charge density, radius, and length, with the problem also addressing the behavior of the electric field when the distance from the center of the cylinder is much greater than its length.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of triple integrals and comparisons to known equations for disks of charge to derive the electric field expression. There are attempts to apply the binomial expansion to simplify the expression for large distances, with some expressing difficulty in achieving the desired reduction. A side question is raised about the validity of using integrals to calculate the electric field inside the cylinder.
The conversation includes various attempts to clarify the expression for the electric field and its limits. Some participants provide guidance on how to approach the side question regarding the electric field inside the cylinder, suggesting the use of symmetry and breaking the problem into manageable parts. There is no explicit consensus on the final approach or solution.
Participants note that the expression for the electric field is valid only outside the cylinder, and there are discussions about the implications of the limit as the distance becomes much larger than the cylinder's length.
nnj3k
1. Homework Statement
(a) Calculate the electric field at an axial point z of a thin, uniformly charged cylinder of charge density ρ , radius R, and length 2L. z is the distance measured from the center of the cylinder. (b) What becomes of your result in the event z >> L ?
2. Homework Equations
I found the answer to (a) by doing a triple integral and then double checked by integrating the equation for a disk of charge given in my textbook over the z-axis and came up with the same exact result. So I am quite confident this expression is correct. The image linked is my work to find the answer if this doesn't look right.
Ez = kq/R2L { 2L + √[ R2 + (z-L)2 ] - √[ R2 + (z+L)2 }
(As a 2nd check...i wrote the expression as kq/z2 { 2L + √[ R2 + (z-L)2 ] - √[ R2 + (z+L)2 } [ z2/R2L ] and in my calculator wrote a quick program to calculate the limit and sure enough...all that garbage on the right goes to 1 as z >> L and R.)
3. The Attempt at a Solution
This expression should reduce to kq/z2 because any charge distribution should mimic a point charge at large distances. The answer to the problem is some type of application of the binomial expansion which I cannot seem to figure out. Everything I try just leads to everything in the bracket except 2L to be zero. Any help is greatly appreciated.
Side Question: This expression is only valid for z outside the cylinder. To calculate z inside the cylinder...is it valid to use the previous integral but changing the bounds from -L to z, and then adding the second integral of the remaining part of the cylinder that is above the charge from z to L and adjusting the radius of dq accordingly, or is there a more simple way to do it?
Hello nnj3k. Welcome to PF !
Your expression,
Ez = kq/(R2L) { 2L + √[ R2 + (z-L)2 ] - √[ R2 + (z+L)2 ] } ,​
should include the parentheses I added to clearly indicate what's in the denominator.
One thing that may help you is to write everything in terms of z/L, since if z >> L, then z/L >> 1 .
For your Side Question: If 0 ≤ z < L,
Break the rod into two pieces.
One piece has a length of 2(L-z) and extends from L-2(L-z) = 2z-L to L. The point, z, at which you're finding the E field is centered in this piece, so the E field, at z, due to this piece is zero.
The other piece extends from -L to 2z-L. Calculate the E field, at z, due to this piece.​
Symmetry is your friend!​
I imagine what you should get for z>>L is something like a point charge with a total charge equal to the charge over the cylinder.
I finally figured out what to do for the limit (it is far too much work for me to be arsed to explain though :P)...and thanks for the tip about symmetry!
  • · Replies 36 ·
  • · Replies 16 ·
