Electric Potential of a Circular Rod
To calculate the electric potential of a circular rod, understanding charge density is essential, as it represents charge per unit length. The potential can be derived using the formula dV = (Kdq)/r, where dq is the differential charge element. Setting up the integral for the potential requires careful consideration of the geometry, particularly the distance from points on the axis to points on the rod. Electric potential is a scalar quantity, which means it adds algebraically rather than vectorially. Clarifying these concepts will help in effectively solving the problem.
Zythyr
http://img136.imageshack.us/img136/7548/44938265by3.jpg
Okay I am not sure how to do this problem without having lambda. I talked to my professor and he said I don't need lambda.
I know that finding the potential due to a continuous charge is
dV = (Kdq)/r
But in this case, I am not sure how to do it. What is dq?
Can someone please explain to me how do I approach doing this problem.
Hmm. I haven't figured out how to do the problem with a simple trick, which it sounds like your professor made one in there.
What is the charge density really? Charge per unit length. You can get the charge density and then integrate like normal. Though the integral is not entirely trivial to set up correctly, so there probably is some kind of trick we are missing.
you need the surface charge. You should have something like dV=bda; where b=surface charge of the tube. from there you input it back into to find V=k/r. at least that is how I would approach the problem.
I am confused.
1. What is the distance of the point on the axis and any point on the ring. Is it different for different point?
2. Whether electric potential is a vector quantity or a scalar and how the two type of quantities are added?
