Electric potential difference question
In summary, electric potential difference is the difference in electric potential energy between two points in an electric field and is measured in volts (V). It is calculated by dividing the change in electric potential energy by the amount of charge moved between the points. The unit of measurement for electric potential difference is the volt (V), and it is directly related to electric current. The two main factors that affect electric potential difference are the amount of charge and the distance between the points, but other factors such as the presence of other electric fields and the type of material can also have an impact.
jaejoon89
195
Two parallel horizontal plates are 0.4 cm apart in air. An oil droplet of m = 4.9*10^-17 kg is introduced between the plates. If the drop has 2 electronic charges and if there is no air buoyancy, you can hold the droplet motionless between the plates if you keep the potential difference between them at...?
Do I use delta V = -int[E*dl] from a to b? How would I incorporate the mass?
For your first question, yes, that is the definition of electric potential.
For your second question, the mass determines how much weight the electric field has to counteract.
Yes, you can use the equation delta V = -int[E*dl] from a to b to determine the potential difference between the plates. The electric field (E) can be calculated using the formula E = V/d, where V is the voltage and d is the distance between the plates. In this case, the distance is given as 0.4 cm.
To incorporate the mass, you can use the equation F = qE, where F is the force, q is the charge, and E is the electric field. Since the droplet has 2 electronic charges, the force acting on it would be 2qE. This force must be balanced by the gravitational force, which is given by mg, where m is the mass of the droplet and g is the acceleration due to gravity.
Setting these two forces equal to each other, we get 2qE = mg. Rearranging this equation, we can solve for the potential difference (V) as V = (mg)/(2q). Substituting in the given values, we get V = (4.9*10^-17 kg * 9.8 m/s^2)/(2*1.6*10^-19 C) = 15.3 V. Therefore, to hold the droplet motionless between the plates, you would need to keep the potential difference between them at 15.3 V.
1. What is electric potential difference?
Electric potential difference is the difference in electric potential energy between two points in an electric field. It is measured in volts (V) and represents the amount of work that must be done to move a unit of electric charge from one point to another.
2. How is electric potential difference calculated?
Electric potential difference is calculated by dividing the change in electric potential energy by the amount of charge that moved between the two points. The formula is V = ΔPE/q, where V is electric potential difference, ΔPE is the change in electric potential energy, and q is the amount of charge moved.
3. What is the unit of measurement for electric potential difference?
The unit of measurement for electric potential difference is the volt (V). One volt is equal to one joule (J) of energy per coulomb (C) of charge.
4. How is electric potential difference related to electric current?
Electric potential difference is directly related to electric current. A larger potential difference between two points will result in a larger electric current, as it provides more energy to move charges through a circuit. This is known as Ohm's Law: V = IR, where V is electric potential difference, I is current, and R is resistance.
5. What factors affect electric potential difference?
The two main factors that affect electric potential difference are the amount of charge and the distance between the two points. The greater the amount of charge, the higher the potential difference, and the closer the distance between the points, the smaller the potential difference. Other factors that can affect it include the presence of other electric fields and the type of material between the points.
  • Electromagnetism
