Elliptical motion about the origin
  • Thread starter Thread starter Identify
    Motion Origin
The discussion focuses on determining the period of a ball's elliptical motion described by the equation r(t)=bcos(ωt)e(x)+2bsin(ωt)e(y). The initial assertion is that the period is T=2Pi/ω, which is confirmed as correct since both the cosine and sine functions have a period of 2Pi. Participants discuss how to find the distance from the origin using the formula |r(t)|, leading to questions about simplifying the expression using the identity sin^2(u) + cos^2(u) = 1. Suggestions include factoring out constants and converting terms to a single trigonometric function for simplification. The conversation emphasizes understanding periodic functions and their properties in elliptical motion.
Identify
A ball of mass m fastened to a long rubber band is spun around so that the ball follows an elliptical path about the origin given by:
b, ω constants
bold type indicates vectors
Find the period of the balls motion.
I think the period is, T=2Pi/ω because the motion is harmonic but I'm not sure if this applies for elliptical motion..?
b, ω constants
Hi Identify, Welcome to Physics Forums.
All you have to do is establish after what time period the function r(t) repeats. What do you know about finding the overall period of a function that is comprised of other functions with their own periods?
Thanks gneill.
I think when 2 periodic functions are added their periods are Pi(the lowest common multiple of the two periods). In this case the answer would be T=2Pi/w, since the period of the cos and sin functions are both 2Pi.
Identify said:
Thanks gneill.
Your result is fine.
To find the distance from the origin I take,
|r(t)|=((bcos(ωt))^2 + (2bsin(ωt))^2))^1/2
Is there a way I can use the sin^2(u) + cos^2(u) = 1 identity to simplify this any further? Or is this the simplified form? If the identity can be used here I am having trouble with the b and 2b coefficients.
Well, you can pull the b out for starters. You could also convert either cos2 or sin2 via your identity to get everything in terms of just sin2 or just cos2.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
