Emergency relief - Plane Vector
  • Thread starter Thread starter Sirsh
    Plane Vector
The discussion centers on calculating the ground speed and direction of an aircraft moving north at 200 km/h while experiencing an 80 km/h wind from the northeast. The calculated direction of the aircraft is approximately 21.8 degrees northeast, while the speed is computed as 215.4 km/h. However, there is confusion regarding the textbook's stated speed of 154 km/h, which seems illogical given the wind's direction. The consensus suggests that if the wind is indeed from the northeast, the calculated speed should not be less than 200 km/h. Clarification is sought on the interpretation of wind direction in relation to the aircraft's speed.
Sirsh
As your aircraft moves in a northerly direction at a constant speed of 200 km h-1, it is
buffeted by winds of 80 km h-1 from the north-east.
Question 1 – What is the ground speed and direction of your aircraft while it is
being buffeted (Hit/pounded) by this wind?
Direction = Tan^-1 (80/200) = 21.8Degrees N-E
Speed = squareroot (200^2+80^2) = 215.4kmh^-1
My direction answer is wrong by a mear 0.3degrees, but, my speed answer is wrong. The answer in the text I'm studying out of says that the speed is 154kmh^-1, Except this is unlogical seeing that the wind is hitting the plane going in a north easternly direction therefore making the vector a addition vector (For example to show that the answer cannot be less then 200kmh^-1), it would seem that if the wind was coming southernly then it would slow down the plane.
Any help would be appreciated. Thanks.
if the question u have doesn't say that the wind is from north-east to south-west .. then ur answer is correct .. if it does then the answer in the book is right..
