- #36
gmax137
Education Advisor
- 2,786
- 2,898
Anskiere said:Yes its really tough to push because you have to do the work to compress the first intake charge, but notice how it suddenly gets really easy after that piston clears TDC?.
Maybe, if you're bump starting a single cylinder bike, but I really doubt you'll feel that on a four cylinder car (much less a six).
The intake charge is essentially an elastic medium in a closed system. Whomever said that the intake charge is acting like a spring is completely correct as I see it.
How do you figure it's a closed system? There will be some air pumped through. And even if not, the compression isn't adiabatic.
Finally, this idea about pumping the air around beneath the cylinders needs more thought - on a multicylinder engine I'd bet there isn't much change in that volume (since there are pistons rising & falling at the same time. Maybe the air pressure within the crankcase isn't rising & falling, but the air is being pushed about, leading to fluid friction. That would explain the drag racing vacuum pumps. But I'd bet the effect is small.
