How Does Ramp Angle and Friction Affect Ice Block Speed?
  • Thread starter Thread starter physicsgirlie26
    Angle Speed
The discussion centers on calculating the angle of a frictionless ramp and the speed of an ice block sliding down it. The ice block, weighing 8.20 kg and released from a height of 1.43 m, reaches a speed of 2.11 m/s at the bottom. Participants suggest using the equations for acceleration down the ramp and normal force to solve for the angle and speed under friction. The introduction of a constant friction force of 11.0 N complicates the motion, requiring adjustments to the acceleration calculations. Overall, the focus is on applying physics equations to determine the effects of ramp angle and friction on the ice block's speed.
physicsgirlie26
A 8.20-kg block of ice, released from rest at the top of a 1.43-m-long frictionless ramp, slides downhill, reaching a speed of 2.11 m/s at the bottom.
What is the angle between the ramp and the horizontal?
What would be the speed of the ice at the bottom if the motion were opposed by a constant friction force of 11.0 N parallel to the surface of the ramp?
I think I use the equations of ax=gsin(theta) and Fn=mgcos(theta)? I'm not sure what to do. Can someone please help me?
Thank you!
With the acceleration component down the ramp, then find the distance traveled to achieve a velocity of 2.11 m/s. It starts at rest.
In the second part, the friction works against the weight component acting down the ramp, so the acceleration is less. Find that acceleration and solve as one does for the first part of the problem.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
