Find angle of a triangle with given sides
  • Thread starter Thread starter fork
    Angle Triangle
To find angle B in triangle ABC with sides AB=7, BC=8, and CA=9, the cosine rule is applied. The calculation involves using the formula cos B = (a² + c² - b²) / (2ac), where a, b, and c are the lengths of the sides. The result is approximately 73.4 degrees when rounded to three significant figures. A calculator is necessary to compute the cosine value accurately. Understanding the cosine rule is essential for solving triangle problems effectively.
fork
In a triangle ABC, AB=7, BC=8, CA=9, find angle B correct to 3 significant figures.
The answer is 73.4, but i don't know how to calculate it, thanks.
Use the cosine rule.
U'll need a calculator to compute B,i.e.solve the equation
\cos B=value
and select the first 3 decimals the calculator shows u...
Daniel.
O, I forgot there is a rule called " cosine rule" in the world, thanks.
The world hath many rules, none of which you ought to ignore..:wink:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
