Find the scalar value and direction of the electric field
The discussion focuses on calculating the scalar value and direction of the electric field at point C, given two charged balls at points A and B. The electric fields calculated are EA = 287680 N/C and EB = 199778 N/C, leading to EC = 255341 N/C. The correct method to find the angle between EC and EA is clarified using the cosine rule, resulting in β = 42.65 degrees, correcting the initial misunderstanding of the formula application.
  • Understanding of electric fields and Coulomb's law
  • Familiarity with the cosine rule in trigonometry
  • Basic knowledge of vector addition in physics
  • Ability to perform calculations involving scientific notation
  • Study the application of Coulomb's law in electric field calculations
  • Learn about vector addition and its role in physics problems
  • Explore advanced trigonometric applications in physics
  • Investigate the concept of superposition in electric fields
Students studying electromagnetism, physics educators, and anyone involved in solving electric field problems in electrostatics.
HJKL
Two charged balls are placed in point A and B and the distance between them is 9,54cm. Each of the balls are charged with 8,0 x 10^-8 C. Find the scalar value and direction of the electric field in point C placed 5 cm from A and 6 cm from B.
Cosine Rule: a^2 = b^2 + c^2 - 2ab x cosθ
E = Ke x (q/r^2)
[/B]
I have calculated the electric field of A and B.
EA = 287680 N/C
EB = 199778 N/C
After that I used cosine rule to calculate EC and got EC = 255341 N/C. This is correct.
But when I try finding the direction I calculate the angle between EC and EA (β) like this:
β = cos^-1 ((EA^2 + EB^2-EC^2)/(2EAEB)) = 60 degrees
The solution says that I should calculate the angle between EC and EA (β), but that the equation looks like this:
β = cos^-1 ((EC^2 + EA^2-EB^2)/(2ECEA)) = 42,65 degrees
Why am I supposed to use that equation?
The wrong thing is your Cosine rule at the first line of your "relevant equation". Please check again :wink:
Oh! No, its not that. I just wrote it down wrong here:smile: I've used c^2 = a^2 + b^2 - 2ab * cosθ, and I get the first part right. I just don't get why I'm supposted to use this equation β = cos^-1 ((EC^2 + EA^2-EB^2)/(2EC EA)) to find the direction.
But...the answer in the solution is a correct answer, just compare to the Cosine rule :eek:
You wrote down the correct cosine rule, as above, but when you put ##E_{A}, E_{B}, E_{C}## into your calculation, I see that you put them in the wrong place
I was a bit confused about which angles goes with which side, but I get it now. Thank you!:smile:
Hope this figure can help you :-p
  • · Replies 16 ·
  • · Replies 26 ·
