Finding magnification, object distance from the mirror, and radius of curvature
The discussion revolves around solving a physics homework problem involving a mirror, where a 10cm high object produces a 5cm high virtual image at -30cm. The magnification is calculated as M = Hi/Ho, resulting in a value of 1/2. To find the object distance, the magnification equation M = -s'/s can be used alongside the lens formula 1/f = 1/s + 1/s'. The radius of curvature can be determined as twice the focal length. The participants clarify that -30cm is the image distance, not the focal length, and provide guidance on how to approach the calculations.
jkeyes2
You placed a 10cm high object in front of a mirror and got 5cm high virtual image at (-30cm). (Hint: watch the sign convention)
a. Find the magnification
b. Find the object distance from the mirror
c. Find the radius of curvature of the mirror
then I have to know if the mirror is convex or concave and if it is upright or inverted, but I think I can figure that out if I find the solutions to these problems.
I've figured out from the information that Ho= 10cm, Hi= 5cm, I think f= -30cm
For object distance, I can't figure out how I can possibly figure that out without any distances given. I'm not supplied with distance from focal point.
Any ideas on what I'm doing wrong?
and for radius, I have no idea where to begin.
for part a. M=Hi/Ho=5cm/10cm=1/2cm ? So does Magnitude equal 1/2cm?
I am not good at science, I am taking this as my gen-ed required science for my major. PLEASE help however you can.
Thanks so much :-)
Hello,
let s= object distance=x, s'=image distance=-30cm, h= object height=10cm, h'=image height=5cm, f=focal length=y and R=Radius of curvature=z
For part A you have the right answer as m=-\frac{s'}{s} Except you thought -30 is focal length which it is not, its where the image appears to be.
For part B you can use the following equation \frac{1}{f}=\frac{1}{s}+\frac{1}{s'}. You don't know object distance but you can work it out from magnification equation, m=-\frac{s'}{s} we also know |m|=\frac{h'}{h} so you can work out what s is.
For part C Radius of curvature is simply 2x Focal length.
Hope this helps
that helps so much! thank you!
