Finding speed of water flowing in a pipe with changing diameter
The discussion revolves around calculating the speed of water flowing through a pipe with varying diameters, specifically focusing on the relationship between flow rates and velocities at different points in the pipe.
  • Participants explore the conservation of mass principle and its implications for volumetric flow rates. There is an attempt to relate the velocities and cross-sectional areas at two points in the pipe.
Some participants have provided guidance on using the continuity equation for incompressible flow, while others are questioning the consistency of the values used in calculations. There is an ongoing exploration of the assumptions regarding the areas and diameters of the pipe sections.
There is confusion regarding whether the values provided for areas are indeed cross-sectional areas or diameters, which affects the calculations. Participants are also grappling with discrepancies in their results compared to expected outcomes.
aija
Water flows in a pipe with speed 1.5 m/s at point 1.
The diameter of the pipe at point 1 is 4cm and the diameter at point 2 is 3cm.
density of water: 998.2071 kg/m^3
What's the speed of the water at point 2?
I think you need to use this. I just have no idea how to find pressures p_1 and p_2 which seems to be needed to get the solution v2 out of this:
p_1+0.5ρ(v_1)^2 = p_2+0.5ρ(v_2)^2
Trying to find the pressure difference p_2 - p_1
At this point I realize it's impossible because you need to use the equation above and it's also needed to solve v_2. No idea what else I could do.
If you assume conservation of matter (water will not spontaneously appear or disappear in the pipe system) and unchanging density then what can you say about the volumetric rate of flow of water past any two given points? Can you calculate the rate of flow?
Thank you I got it. So the volume flow rate vA is constant so
v_1*A_1=v_2*A_2
V_2=-(v_1*A_1)/A_2
Still getting a wrong answer. Is something wrong in my equation?
with values
A_1 = 3.5 cm
A_2 = 2.5 cm
v_1 = 2.0 m/s
i get 2.8 m/s and it's wrong.
the correct answer was 3.9 m/s. But why did I get a wrong answer?
with values
A_1 = 3.5 cm
A_2 = 2.5 cm
v_1 = 2.0 m/s
Those look like different values from those in your original post. Are A_1 and A_2 supposed to be cross sectional areas or diameters? (The given units suggest diameters).
If they are diameters then they lead to a result of 3.92 m/s .
Oh thanks. I accidentally used diameters as areas...
  • · Replies 47 ·
  • · Replies 16 ·
  • · Replies 30 ·
