Finding the acceleration of two masses on a pulley system
The discussion focuses on calculating the acceleration of two masses connected by a pulley system, where one mass (m1) is on a surface and the other (m2) is suspended. The system is initially in equilibrium but will start sliding if m2's mass increases. Participants clarify that the coefficients of static and kinetic friction are equal, indicating friction is present. The horizontal acceleration of the surface is given as 5.43 m/s², but the horizontal acceleration of m2 is determined to be zero, as it does not directly respond to the surface's movement. The relationship between the accelerations of m1 and m2 is emphasized, with the conclusion that the string's constant length affects their acceleration dynamics.
  • #51
So I guess my question is which of these two equations do we use in the tension force equations (if either is correct...and if my tension force equations are correct...):
a2= -asurface + a1
a2= -2a1
  • #52
Jpyhsics said:
a2= -asurface + a1 ?
Which way are you defining as positive for asurface?
  • #53
Jpyhsics said:
it seems as though the acceleration of the surface is not needed
You are to find the accelerations of the masses in terms of the acceleration of the surface.
  • #54
So I went through the entire question with +x as left and +y as up, I got to the two equations a(2) = 2a(1) and -a(2) = a - a(1) and solved for a(1) = -a. Yet I got the incorrect answer, what did I do wrong?
  • #55
FriedChicken885 said:
-a(2) = a - a(1)
If you are taking a2 as positive up and a1 positive left then you have a sign error there.
  • #56
I also tried it for:
a2 = 2a1 and a2 = a - a1 and solved for a1 = ⅓a, but that's still the incorrect answer. Also I wonder if I'm missing something since I don't use the given value of m1.
  • #57
a2 = a - a1
still the wrong combination of signs.
The easiest way to get this right is to imagine holding one acceleration at zero and thinking how the other two interact.
Since a1 and a2 are both positive towards the pulley, if a were zero their sum would be constant. So we have a1+a2= f(a).
If we imagine a2 held at zero but the string remaining taut then m1 must be at constant distance from the pulley. Since a is positive right but (bizarrely) a1 is positive left then, again, their sum must be constant. This leads to a1+a2= -a.
  • #58
So does this solution make sense to you?
  • #59
haruspex said:
a1+a2= -a.
I again tried solving that solution with the system of equations:
a1+a2= -a and a2 = 2a1
and I got a1 = (-1/3)a which is still incorrect despite every step seeming to be correct.
Also do we need to use the numerical value for m1 at all?
  • #60
hmm.. that is the answer I get.
No. Only the ratio of the masses can be relevant.
  • #61
That is the same as the general equation I obtained.
  • #62
So I plugged in my values and it was wrong, so I don't really know what else to do.
  • #63
Okay, thank you very very very much for all of your help!
  • #64
Should one not consider that the tension supporting the hanging mass is no longer parallel to the vertical side of the table but at an angle?
Also, I think that ##g=9.81 ~m/s^2## in the expression posted by OP in #62 should be replaced by an effective acceleration. This problem can be solved quite simply in the accelerated frame with additional fictitious horizontal forces ##-m_i\vec a_0## acting on masses ##m_i##. Here, ##\vec a_0## is the given horizontal acceleration of the table.
  • #65
we are asked for the accelerations immediately after the surface has started to accelerate. The string is still vertical.
I don't see why. Do you get a different answer? If so, please post your solution.
  • #66
I don't get a different answer, but I am bothered by the fact that one writes the same equation for the hanging mass whether the pulley supporting it accelerates or not. When the pulley accelerates, the hanging mass must have a horizontal acceleration at t = 0 because its horizontal position changes a moment later. Should this not affect the tension? I need to think about this some more.
On Edit: OK, I got it. At t = 0 the horizontal acceleration is instantaneously zero and then changes as it reaches a constant value in the steady state.
  • #67
Right.
Or maybe oscillates.
