Finding the tension of a support cable to balance the beam
The discussion revolves around determining the tension in a support cable that balances a beam, involving concepts from statics and torque analysis.
  • Participants explore the relationship between forces and torques acting on the beam, with one participant attempting to derive the tension through backward calculations. Others raise questions about the center of mass and the forces involved.
The discussion is ongoing, with participants providing hints and exploring different aspects of the problem, such as the center of mass and the forces acting on the beam. There is no explicit consensus yet.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply.
JohnTheGreat101
Find the tension in the support cable needed to balance the beam
0=tc + tbl - tbr - tcyl
I know the answer is 170 but I am not sure how to get there. I tried doing things backwards
g=9.8
t = fr = mgr
0= 170 + tbl - tbr - 5x9.8x1.5
0= 170 + tbl - tbr - 73.5
-96.5 = tbl - tbr
-96.5 = 18*9.8 * 0.2 - 18*9.8*1.4
-96.5 does not equal -211.68
Hint: Where's the center of mass of the beam?
Ok so I found the mass of the cable. mgr/gr = m
170/9.8x1.2 = 14.46 kg.
COM = 5 kg x 1.5m + 14.46 kg x 1.2 / 14.46 + 5 = 1.28 m
There are three forces acting on the beam that create torques about the fulcrum:
  • The downward force of gravity on the beam. (Where does it act?)
  • The upward force of the cable. (Which is what you are trying to find.)
  • The downward force of the cylinder's weight on the beam.
Add up the torques due to these forces.
  • · Replies 19 ·
20K
