Finding the value of an integral given a graph
turbokaz
http://tinypic.com/view.php?pic=1xa2f&s=5 (this shows the graph that is related to the problem)
is the graph of an anti-derivative, F, of a
function f, use this graph to determine the value of I=∫ from 0 to 8 |f(x)|dx.
value of the definite integral
The answer choices are 11, 12, 13, 14, or 15. I have no idea how to get these answers. I looked at the graph and used Reimann Sum technique of counting up the squares, but I get numbers in the 20's. For absolute value functions, I know you switch any negative values to positive, but this whole function looks positive to me? Thoughts?
Hi turbokaz,
The plot is the antiderivative already, no need to integrate it further.
How do you calculate the definite integral between two points from the antiderivative?
What do you think about the sign of f(x)? In what domain is it positive and where is it negative?
ehild
F(b)-F(a)?
F(b) is 1, F(a) is 2. 1--2=3?
Bump...I'm still not getting anywhere
Nevermind. I understand the problem now. The answer is 11.
Congratulation!:smile:
ehild
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
