Finding total resistance in parallel circuit
This discussion revolves around a problem involving the calculation of total resistance in a parallel circuit containing multiple lamps with different wattages connected to a 110-volt source. The original poster has attempted to solve parts of the problem, including calculating the current and resistance for each lamp.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster calculates the current and resistance for each lamp using formulas based on power and Ohm's Law. Some participants question the accuracy of the method used for calculating total resistance in parallel circuits and raise concerns about significant figures in the calculations.
Participants are actively discussing the method for calculating total resistance and the importance of significant figures in the calculations. Some guidance has been provided regarding the precision of the calculations, and there is an ongoing exploration of the implications of these precision issues on the results.
There is a focus on the accuracy of calculations and the proper handling of significant figures, which may affect the validity of the results. The original poster has expressed confusion regarding these concepts, indicating a need for clarification.
kriegera
This is a 3-part problem of which I have solved 1 and 2. I've included here just so you can follow the problem. A 50-watt lamp, a 20-watt, a 75 watt lamp, and a 100-watt lamp are connected in parallel to a 110-volt circuit. Calculate a) the current through each lamp; b) the resistance of each lamp; c) the total resistance of the circuit.
a.) Current is calculate by I=P/V where P is in Watts so 
I=50/110 = .45 A
I=20/110 = .18 A
I=75/110 = .682 A
I=100/110=.91 A
b.) Here we use Ohm’s Law again: R = V / I
For 50 Watt lamp  R=110/.45 = 244.4 Ω
For 20 Watt lamp  R=110/.18 = 611 Ω
For 75 Watt lamp  R=110/.682 = 161.29 Ω
For 100 Watt lamp  110/.91 = 120.88 Ω
c.)To find total resistance of the circuit in parallel, use
R=1/(1/244.4) + (1/611) + (1/161.29) + (1/120.88) = 49.5 Ohms
I've seen many ways to calculate resistance - but is it accurate to do it this way for a parallel circuit?
Yes, that's the method to do it. :approve:
I assume that by your equation you mean
R_{eq} = \frac{1}{\frac{1}{R_1} + \frac{1}{R_2} + \frac{1}{R_3} + \frac{1}{R_4}}
However, you should probably go back and re-do your answers for part a and b. The precision you used (i.e. significant figures) was small for part a, then you used a higher precision for part b, based on your low-precision answers from part a. Doing so causes some of the significant figures in your answers to part b to be pretty meaningless.
Yes, that's the equation I mean. I'm a little confused - what do you mean by "significant figures" were small and "higher precision"? thanks!
As an example of the work you did already, you had (for the 50 W bulb)
I=50/110 = .45 A
Notice, you've calculated out the resistance to 4 significant digits, but the current was only calculated out to 2 significant digits.
You might be more careful with significant digits, especially early on. Continuing this example, suppose we used 5 significant figures (digits) from the beginning. Then,
I=50/110= 0.45454 A
And R = 110/0.45454 = 242.00 Ω
It's easier to calculate the resistance by calculating R = V/I_{total}
got it:
For 50 Watt lamp  R=110/.4545 = 242.0 Ω
For 20 Watt lamp  R=110/.1818 = 605.0 Ω
For 75 Watt lamp  R=110/.6818 = 161.3 Ω
For 100 Watt lamp  110/.9090 = 121.0 Ω
c.) To find total resistance of the circuit in parallel, use
R=1/(1/242.0) + (1/605.0) + (1/161.3) + (1/121.0) = 49.38 Ohms
THANKS!
