Calculate Flux Density of Current Loop
In summary: I need to find.In summary, to find the flux density of a current loop with a diameter of 8cm and a current of 15A, you can use the equation B = permeability x current / 2 x radius. After substituting the values, the answer is 2.36 x 10^-4 Wb/meters squared. Other equations such as B = H x permeability and H = current / area can also be used to solve this problem.
LandonV
Loop like an "O" with current moving to the left
Diameter = 8cm
Current = 15A
FIND THE FLUX DENSITY OF THE CURRENT LOOP IN THE PLACE OF THE LOOP?
B(flux density)=F(magnetic flux)/A(area)
B=H(magnetic field strength)*Permeability
H(magnetic field strength)=I(current)/A(area)
A(area)=Pi*r(radius)2
L(inductance)=Ioda(magnetic flux)/I(current)
Ioda(magnetic flux)=V(velocity)xT(time)
(permeability)=L(inductance)/d(diameter)
Area = 50.24 = (3.14 *(42))
Magnetic Field Strangth = .299 or .3 = (15/50.24)
From this point I am lost because it appears to me that I am missing a key part to finish the equation. If I can find out the time or the charge then I can do some substitions and find the answer the equation. Can anyone point me in the right direction?
These are the possible answers:
1. 1.68 x 10^-5 Wb/meters squared
2. 2.36 x 10^-5 Wb/meters squared
3. 1.68 x 10^-4 Wb/meters squared
4. 2.36 x 10^-4 Wb/meters squared
5. 2.87 x 10 Wb/meters squared
That second equation might come in handy.
That en lies my problem...
For that equation, I need to find permeability!
To find permeability I need to find inductance
To find Inductance I need to find magnetic flux
To find magnetic flux I need to find velocity and time!
How am I to find 2 items to which I am unable to derive a possible answer for?
can no one show me what it is that I am missing in this problem?
Isn't this just the Biot-Savart law? That should be all you need. You have too many equations.
Well I was given no equations to work with because i missed this day in class and I am playing catch up so I am lost. These were the "relevant" equations that I could find. I am going to have to look up Biot...appreciate the possible direction point!
After doing some more investigation, I tried another avenue but to no avail.
Permeability = 4Pi x 10^-7 H/m (IN A VACUUM)
B(magnetic flux) = H(magnetic field strength) * permeability
B = .3*(4Pi x 10^-7)
B = 3.768 x 10^-7
But it is not the answer according to my instructor...he gave me a list of options as show above but I can't seem to get there. Anyone?
QUESTION AND EQUATION ANSWERED!
B = (4Pi x 10^-7) x 15A / 2 x (.04 meters)
B = 2.355 x 10^-4 (rounded off = 2.36 x 10^-4)
so
B= Permeability x Current / Area
2 x radius looks strongly like a diameter rather than an area
Yeha I am not exactly sure how any of this works because I missed the last 2 classes and I am playing catch up and it sucks but the list of equations that I originally found were the ones I listed and they didnt help me in anyway but after doing some reading I found the equation that I used in my last post and that gave me the answer I was looking for so I have no clue how these equations supposedly tie in together but my instructor said my answer was correct so I am not complaining about that...just sucks that I can't figure out how this all ties in together
1. What is flux density in a current loop?
Flux density, also known as magnetic flux density or magnetic induction, is a measure of the strength of a magnetic field within a given area. In a current loop, it refers to the amount of magnetic flux passing through the loop per unit area.
2. How do you calculate the flux density of a current loop?
The flux density of a current loop can be calculated using the formula B = μ0 * I / (2 * π * r), where B is the flux density, μ0 is the permeability of free space, I is the current in the loop, and r is the radius of the loop.
3. What is the unit of measurement for flux density?
The unit of measurement for flux density is Tesla (T), which is equivalent to 1 N/A·m or 1 kg/(A·s^2).
4. How does changing the current or radius of a loop affect the flux density?
According to the formula B = μ0 * I / (2 * π * r), increasing the current in the loop will result in a higher flux density, while increasing the radius of the loop will decrease the flux density. Similarly, decreasing the current or radius will result in a lower flux density.
5. Can the flux density of a current loop be negative?
Yes, the flux density of a current loop can be negative. This indicates that the direction of the magnetic field is opposite to the direction of the current in the loop.
