Muhammad Uthman
- 10
- 0
Why does fly wheel return in opposite motion after it comes to rest due to friction?
Muhammad Uthman said:Rim? Hub? Spokes?
Bystander said:I was thinking more in accumulated shaft lengths, pedestals, frames, linkages.
Muhammad Uthman said:String and weight falls and it continues to rotate until comes to rest and rotates in opposite direction.
A flywheel with this trait would have - let's say ... undesirable side effects.[EDIT] ohhhh. This is a high school flywheel. I was imagining a 10kg flywheel rotating at 30,000 rpms, developing a slight ... wibbly-wobble.NascentOxygen said:If it wasn't perfectly symmetrical it would want to turn until the heavy spot was downwards,
What type of flywheel do you mean?Muhammad Uthman said:Every flywheel of this type does so.
Every spin returns?jerromyjon said:Almost anything that spins does it, more so with greater resistance.
Why does it reverse direction after spinning to a stop? Why does fly wheel return in opposite motion after it comes to rest due to friction?Muhammad Uthman said:Why does fly wheel return in opposite motion after it comes to rest due to friction?
The image was an example, the string and weight have to be removed.dean barry said:at the bottom of the weights journey the string is wound back up in the opposite direction
