What Is the Maximum Amplitude of Harmonic Motion Without Slippage?
The discussion revolves around calculating the maximum amplitude of harmonic motion for a system of two blocks and a spring on a frictionless surface, ensuring no slippage occurs between the blocks. The top block's maximum acceleration must not exceed the static friction force, which is determined by the coefficient of static friction and the weight of the top block. The spring force is expressed as F = kx, where k is the spring constant and x is the displacement. The combined mass of the blocks is crucial for determining the acceleration during motion. The participants are trying to reconcile the forces acting on the blocks to find the correct amplitude while addressing the relationship between the blocks' accelerations.
ViewtifulBeau
Two blocks (m = 0.468 kg and M = 2.41 kg) and a spring (k = 24.1 N/m) are arranged on a horizontal, frictionless surface. Block m is situated on top of block M. (Spring attached to block M) The coefficient of static friction between the two blocks is 0.873. What is the maximum possible amplitude of simple harmonic motion of the spring/blocks system if no slippage is to occur between the blocks?
Im not too sure what to do with this problem, I think i have to match up the normal force on the top block with the force of the spring on the bottom. but I am not sure.
In order for the large block (mass M) to move without slippage of the small block (mass m), the acceleration (a) of the small block must be such that the force F=ma, must not exceed \mumg.
The spring imposes a force on (M+m), and the spring force Fspring[/sup] = kx.
i did that and i got .166 meters. umg = .873*9.81*.468 = 4.008 N
F(spring) = kx
4.008 = 24.1 * x
x = .166 meters.
and this is not right. What am i doing wrong?
The block on top, m, are also experiencing SHM. The force that causes it to experience SHM is the frictional force. Since this force has an upper limit it puts a limit on the maximum acceleration the top block can experience. Are the acceleration of the two blocks the same during the motion?
F(spring) = kx
4.008 = 24.1 * x
The spring force must be applied to the combined mass (m+M) = 0.468+2.41 kg, but one needs the acceleration of the combined mass to determine F, from which one applies F = kx or x = F/k.
The problem then is - what is the acceleration of the combined blocks, knowing that the small block and large block accelerate together?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
