Helical Twist Vertical Axis Wind Turbine - Generator Matching
The discussion centers on a helical twist vertical axis wind turbine designed for improved wind capture but currently achieving only 4% efficiency in converting wind power to electrical power. The user is experiencing low output from their DC motor generator, with a no-load voltage of 4.5V and a short-circuit current of 0.02A at wind speeds of 6-7m/s. They aim for an output of 4.5V and 0.25A to power a mobile phone via USB. The user has identified a peak power output of 0.07W with a 60Ω load resistance. Suggestions for improving efficiency include experimenting with the pulley ratio used in the system.
FanMan
Hello
I have designed a vertical axis wind turbine (Savonius) with a 180deg helical twist. It catches the wind really well but the wind power to electrical power conversion is really poor, it is currently only at 4% efficiency. I think the problem is the dc motor that I am using as a generator. I currently have a no load voltage of about 4.5V and a short circuit current of 0.02A at a wind speed of 6-7m/s. Ideally I'd like 4.5V, 0.25A so that I can power a mobile phone via USB. The motor is rated at 800rpm/V. I used a variable resistor to find the peak power, this occurs with a 60Ω load resistance and is 0.07W (2.26V, 0.034A). Also I am currently using a pulley system with a ratio of 5.2:1, it is a basic pulley with an elastic band. Any help would be greatly appreciated!
Thanks in advance
Hi, FanMan;
I know nothing about the subject, so I probably won't be of any help. Just wondering, though, if you've experimented with altering the pulley ratio.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
