How can i know the current gain of transistor fom its data sheet?
The current gain (Hfe) of a transistor, as listed in its datasheet, is specific to a certain collector-emitter voltage (Vce) and can vary significantly between individual transistors of the same type. Hfe is influenced by factors such as temperature, collector current, and Vce. While the value at a specific Vce (like 4 volts) is a reference point, it remains relatively constant across a range of Vce values, provided Vce is above the saturation voltage and below the breakdown voltage. The datasheet typically provides typical values, acknowledging this variability. Understanding these nuances is essential for accurate circuit design and analysis.
tefavolc
how can i know the current gain of transistor fom its data sheet??
when i open a datasheet for a certain transistor i find a relation between Ic and Hfe at a certain Vce (ex Vce=4 volt), did this relation only correct at that Vce ? and if its that how can i calculate the Hfe for a certain Ic at any other value of Vce ? ?
i attach a data sheet for example
First you should know that Hfe will vary from one transistor to the next, even if it's the same type (eg tip31A), that's why the datasheet lists "typical' values.
Additionally, for any given transistor, Hfe will also vary as a function of temperature, as a function of collector current, and as a function of Vce.
The variation of Ic/Ib with collector voltage is large as you approach saturation but not so large for bigger values of Vce.
So to answer to your question, the value of Hfe given at Vce=4 volts will remain approximately constant for a range of Vce values, provided Vce stays greater than about a volt more than Vce_sat (and of course less than the Vce breakdown voltage).
Note that the DC current gain plotted in Fig.1 of your transistor is plotted at a Vce that maximizes current gain.
Bob S
thnx for replaying
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
