How Does Doubling Mass and Force Affect Acceleration?
  • Thread starter Thread starter 5.98e24
    F=ma Proportional
The discussion revolves around the relationship between mass, force, and acceleration in the context of Newton's second law of motion. Participants are examining a scenario where an object is accelerated by rubber bands, with a focus on how doubling both the mass and the force affects the resulting acceleration.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the implications of doubling mass and force on acceleration, questioning the assumptions made in the calculations. There is an attempt to clarify the relationship between force, mass, and acceleration using the equation F = ma.
The discussion is progressing with participants providing insights into the calculations and assumptions. Some have recognized the importance of considering both the doubling of mass and the doubling of force, leading to a clearer understanding of the problem dynamics.
There is a mention of specific conditions, such as the use of rubber bands and the standard length, which may influence the forces applied. Participants are navigating through the implications of these conditions on the acceleration outcomes.
5.98e24
Two rubber bands stretched to the standard length cause an object to accelerate at 2 m/s^2. Suppose another object with twice the mass is pulled by four rubber bands stretched to the standard length. The acceleration of this second object is: ??
The correct answer is 2m/s^2.
F = ma
a = F/m
a = F/m
Therefore, a is inversely proportional to m.
a1/a2 = m2/m1
Second mass is twice the first mass.
a1/a2 = 2m/m
m's cancel out, leaving:
a1/a2 =2
Isolate a2:
a2 = a1/2
That would make my acceleration of the second object 1 m/s^2, not 2 m/s^2. Did I miss something?
If you double the force and double the mass, how will acceleration be affected?
Perhaps do this in steps.
1. Double the force, by using 4 rubber bands, keeping the original mass. What is the acceleration now?
2. Using the same force as in (1.), 4 rubber bands, now double the mass. What is the acceleration now?
F = ma
a = F/m
a = F/m
a1/a2 = m2/m1
a1/a2 = 2m/m
a1/a2 =2
Isolate a2:
a2 = a1/2
You assumed the forces were the same when the mass doubled, which cuts the acceleration in half, as you noted, however, it is given that the forces were also doubled when the mass doubled, so doubling the force now doubles the halved acceleration back to the same acceleration of the first object. Do you follow, or does this double your trouble? :wink:
Ah, I see now.. forgot to consider the doubling of the forces.
Thank you both!
  • · Replies 97 ·
17K
  • · Replies 20 ·
12K
  • · Replies 24 ·
