How to calculate the voltage on a resistor at a power cable
The discussion revolves around calculating the voltage across a resistor connected to a power cable, involving concepts from electrical circuits, specifically Ohm's law and resistance calculations. The problem includes parameters such as resistance of the resistor, voltage at the beginning of the cable, length of the cable, and material properties of copper.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to calculate the voltage by determining the resistance of the cable and combining it with the resistor's resistance to find the current. Some participants question the details of the calculations and suggest that the implementation may contain errors.
Participants are actively discussing the calculations and seeking clarification on the original poster's method. Some guidance has been offered regarding the need for more detailed steps to identify potential mistakes. There is acknowledgment of agreement on the calculations presented, but no consensus on the correctness of the final answer.
The problem is part of an online homework system, and there is a suggestion that the feedback from the system may be incorrect, which adds a layer of uncertainty to the discussion.
ronaldinho52
hallo everyone,
i have here a simple problem that i cannot solve. This is the problem:
A resistor of 46 Ω is connected to the end of a power cable.
The voltage a the begin of the cable is 230 V.
The length of the cable is 25 m
The copper area is 1.0 mm2
The specific resistance of copper is 0.0175.10-6 Ω.m
What is the voltage on the resistor of 46 Ω [in V]?
I calculted this by first determining the resistance of the cable and then adding(series) both the resistance of the cable and the resistor. After this i have calculated the current in the cable. With the current known the voltage of the resistor can easily be calculated using V=IR.
This seems to be right to me but the answer is wrong. Does someone know what my mistake is and how this problem can be solved.
thanks to everyone
Hi ronaldinho52 and welcome to PF. Your method seems to be OK. You probably went astray with the implementation. Can you show exactly what you did in more detail? We cannot help you without more details.
Answer should be 227.833 Volts.
So i first calculate the resistance of the cable:
R(cable)=(0.0175x10e-6 x 25 m)/1e-6=0.4375 ohm
Total resistance is R(cable)+R(resistor)=0.4375+46=46.4375
Now the current in the serie can be calculated: 230/46.4375=4.953 amp
So, the voltage across the resistance is 4.953 amp x46 ohm=227.83 Volts
unfortunately this answer is wrong. This problem is part of a online homework system which i must work out every week. Maybe its an error in the system itself which gives an incorrect feedback.
I agree with your calculation and it seems that 1994Bhaskar does too. Perhaps you should ask the person who assigned this problem for clarification.
  • · Replies 60 ·
10K
