Japan Earthquake: nuclear plants Fukushima part 2
In summary, there was a magnitude-5.3 earthquake that hit Japan's Fukushima prefecture, causing damage to the nuclear power plant. There is no indication that the earthquake has caused any damage to the plant's containment units, but Tepco is reinforcing the monitoring of the plant in response to the discovery of 5 loose bolts. There has been no news about the plant's fuel rods since the earthquake, but it is hoped that fuel fishing will begin in Unit 4 soon.
  • #1,191
http://www.tepco.co.jp/nu/fukushima-np/handouts/2017/images1/handouts_170327_14-j.pdf (in Japanese)
Updated report on the robot investigation of Unit 1 PCV.
A lot of the content has been presented in previous reports so I will mention just a few new aspects:
- Page numbered 5, "blue" object filmed on the floor (Photo D0-3) is a "fallen object".
- Page 6, photo at top left: "pre-existing structure"; bottom left: "fallen object"; bottom right: "fallen object(s)".
- Page 7: Radiation dose measurements in various points, on the grating (first row of the table) and at the lowest point reached by the hanging measurement unit (second row in the table, height from floor also noted).
- Page 8: graphs showing the variation of the measured dose as a function of the height from PCV floor, in various points BG, D0...D3. Group of numerous points in the left are for underwater measurements. Then there are a few measurements right at water surface (at almost 2m on X axis) and a few more on the grating (at 3.5m on X axis).
- Page 9, conclusions:
- This was the first opportunity to film the bottom of the PCV around the area of the opening in the pedestal wall. It was also possible to verify that radiation doses increase as we get closer to the PCV bottom.
- Sediment was observed on the bottom of the PCV, around pipes etc. Research/analysis on the nature of the sediment will continue.
- It was attempted to get close and film the sediment at point D2. From the fact that the sediment did not rise/float into the water it is deduced that it does have a considerable weight.
- When the measuring unit enters the w3ater, the radiation dose decreases, however it rises as the unit gets closer to the bottom.
- The height (measured from the bottom) where the radiation values appear to increase varies from one point to another. (There are many hypotheses for the cause of this phenomenon. The sediment could be the radiation source, there could be a strong source sticking to the bottom under the sediment, there could be fuel debris close to the PCV bottom...)
- The radiation doses measured on the grating did not differ much from those observed in April 2015, and no major destruction of the structures was observed.
- The analysis of the images and data will continue.
- Page 12: shows, in section, several of the places where the underwater measurement unit was lowered. Emphasis on the PLR pipes. (Radiation doses of 5.9 to 9.4 Sv/h, according to Page 7).
- Page 14: shielding with lead plates in the area of the PLR pipes.
Edit: slightly larger photos and a 300 Mb movie - here:
http://photo.tepco.co.jp/date/2017/201703-j/170327-01j.html
Likes turi
  • #1,192
A couple of things I understood from watching the robot video and the press conference related to this last report.
- What they meant to convey by the diagrams of Page 12-14:
When they lowered the underwater measurement unit in the area of points D1-D2, they had to stop at a height of about 90 cm from he floow, because there was already a surface of sediment at that height. Incidentally, those points where the unit had to stop also coincide roughly with the top of the PLR pipe as shown in Page 12. Add to this - as seen on page 14, which by the way is a photo of Unit 1 during scheduled maintenance work - the fact that on the side of that particular portion of the PLR there was, installed by design, a shield made of lead panels. So, there is a possibility that that shield collapsed or melted partially and fell over the PLR pipe, and what now appears to be a "90 cm thick layer of sediment", in which they ran into when lowering the measurement unit, is in fact a sheet of lead that fell om the PLR and is covered with some dust. They hope to learn more about this sediment and its thickness by further analyzing the imagery taken.
The diagram onm page 13 shows another place which appears in the film/photos, namely the valve wheel that is photographed pretty clearly close to the bottom of the PCV. That is one place where they managed to get as low as 30 cm above the floor.
- On page 6, the top right photo shows a weird yellowish stain at D2 (3), which I couldn't figure out earlier what it meant and I thought it might be due to high radiation. It appears that is an effect of getting very very close to the filmed surface (of the sediment), so that the LEDs that provide light cannot actually illuminate the center area enough for an image to form. So it's just a shadow.
- The video images at D1(2) (around 05:15 in the video) transiently show a black mass at the edge of the field of view, which perhaps would deserve more investigation.
- There is some light stuff floating in the water - but they are still happy with it's transparency, it could have been worse, as it is it allows a reasonable viewing.
- They hope to carry out the final step of this investigation - taking a sample of the water/sediment - ini the following days, as soon as preparations are done.
- They are making progress - even if slowly - with the robot for Unit 3, which they hope to be able to send in the PCV sometime this summer.
Likes Dundeephysics, Charles Smalls and turi
  • #1,193
Charles Smalls said:
Is it possible that the sand/sediment we see in the latest footage is from this process where the fuel has met the CV concrete floor and caused this large amount of spalled material?
In case of U1 it's likely that all the core material escaped the RPV, so some kind of interaction with the concrete floor is expected.
However: I expect it within that well-like concrete structure. But the actual investigation is about the floor around that structure, not inside.
I don't know how mobile the materilas from MCCI are, but this amount of sediment just feels wrong.
  • #1,194
How much sediment do we actually expect?
Wikipedia says the core contained roughly: Uranium dioxide 78.3 tons; Zirconium 32.7 tons; Steel 12.5 tons; Boron carbide 590 kilogram; Inconel 1 ton.
A simple calculation based strictly on the density of the first 3 materials gave me a total volume of about 10 cubic meters.
With the pedestal having an internal diameter of 5 meters, if all those materials melted and went to the bottom (let's ignore the opening in the pedestal at this time) I get a height of the "cylindrical layer of debris" of about 50 centimeters, if it behaved like a liquid and filled all the space evenly.
Since it probably didn't behave exactly like that, we can assume an uneven distribution (actually suggested by the latest investigation too).
So 90 cm might not be that out of scale after all? But if so, how come the radiation values are so low (with water and all, Tepco spokespersons said if that was fuel debris the values close to the sediment layer should have been higher).
...would somebody please check my calculations :)
Likes Dundeephysics and turi
  • #1,195
But it's not about core debris, but about burnt concrete what became mobilized and relocated from inside of the pedestal to outside.
There was some calculations: in case of complete core relocation it was ~ 70cm deep penetration in concrete as I recall. I'll try to dig this up later.
Likes Charles Smalls
  • #1,196
Right, Rive - I forgot that the melted stuff attacked and bore into the concrete base.
Oversimplification of course... Plus the opening in the pedestal clearly allows some (a lot?) of materials to get out into the PCV.
But unless there was a lot of vaporization of solids, It seems to me that most of the mentioned volumes should still be laying somewhere around there.
  • #1,197
Actually I did forgot one thing - it's possible that if inside of the pedestal had an aggressive water input then that could relocate the mobolized sediment and deposit it on the outside.
  • #1,198
Well at least you had the locations right.
Unfortunately I was speaking of the sediment height inside the pedestal - whereas this time's investigation and the reported "90 cm debris?" were all outside of the pedestal wall... I will step back, clearly I don't know enough. I can't even begin to imagine the physical processes that took place in those moments in the pedestal area.
  • #1,199
With the pedestal having an internal diameter of 5 meters, if all those [fuel] materials melted and went to the bottom (let's ignore the opening in the pedestal at this time) I get a height of the "cylindrical layer of debris" of about 50 centimetres.
The opening in the pedestal and it's location may have a lot to do with these weird sediment/sand images.
In the TEPCO report, location D2 is where the camera observed the thickest sediment deposits:
If this material was from concrete heat spalling, this would make sense because D2 is directly opposite the pedestal opening and the first place the core melt would have spread after leaving the pedestal. If the PVC proper was dry, this is where the core-concrete interaction would have begun.
Page 1 of the TEPCO report seems to show similar thinking:
On the right they show a gray puddle exiting the pedestal via the yellow doorway into the PVC proper. If this was fuel melt encountering the concrete floor, you would expect erosion/spalling to take place heavily here. On the floor above they show the robot in position D2 where it was when it lowered the camera and captured the sediment images.
This is the part that doesn't add up. On the video it looks like they basically lower the camera all the way down until it hits the surface of the sediment. If it was a loose amalgamation of materials as spalled concrete normally is, I would have expected this impact to have thrown some of the sediment into suspension and clouded the water. It could be that the material is too heavy to be dislodged by such a light impact or maybe it formed a depression which the camera didn't pick up. I would be very interested to learn more on the make up of the sand/sediment i.e. particle sizes and whether it is loose material or a solidified mass.
Likes Sotan
  • #1,200
Wait until there's a handful of the stuff gathered up to analyze.
I was never inside a BWR containment..
In mine there's normal dust . Cable trays were all sprayed with fireproofing material "FlameMastic" a fibrous mix of something akin to latex paint and i think asbestos.
I would think inside a containment that's been subjected to prolonged loss of cooling and pressure-cooker steam a lot of mud would result from soggy thermal insulation , peeled paint, maybe even melted pvc electrical insulation . Seawater injection had to carry in a lot of solids if only salt .
Were i looking for Corium i'd turn off the lights and look in the water for telltalle blue glow of Cerenkov .
Likes Sotan
  • #1,201
I think I have it.
- The core were relocated, broke the RPV and ended in the slump pits within the pedestal. It started to burn the concrete.
- Not so long after that there came a lot of water through the RPV and ended within the pedestal through the holes of the RPV.
- The water started to move the burnt concrete and carried it through the pedestal opening. I think some of it ended in the torus.
- Since there was a strong water stream through the pedestal opening, we can see a sediment pad in front of it and a depression toward it where the stream was strong enough to carry away everything. That slight depression might be seen on that 13:05:38 picture.
If I got it right then the sediment should be rough near the pedestal opening and should has finer particles further away.
There was some complaining here as I recall when for the first inside peek they forgot to switch off the light :cry:
Likes Sotan
  • #1,202
The pictures from under the reactors do not show an environment that was subjected to a corium melt and heat soak. There are way too many small features visible that would have melted and slagged down to the bottom. You can't melt through a 10" steel vessel, transport TONS of steel melting material into a confined space and still have things like flat mild steel grates, Control rod cables, wires visble.
What you guys are describing as a corium melt would look more like this. (Slag dump).
More then likely we have fuel pellets that melted through their cladding, spilled out and piled up in the bottom of the RPV. When the reactors depressurized high velocity steam pulverized those loose ceramic pellets into find dust and this fuel material was transported out of the RPV with the steam and water.
Just my thoughts on the matter.
Likes Sotan
  • #1,203
Cire said:
The pictures from under the reactors do not show an environment that was subjected to a corium melt and heat soak. [...] You can't melt through a 10" steel vessel, transport TONS of steel melting material into a confined space and still have things like flat mild steel grates, Control rod cables, wires visible.
The images from the unit 2 CRD room show almost exactly that same thing can happen; the environment was subjected to corium heat, which had melted through the steel RV directly above, but the nearby steel grates and control rod cables still remained visibly intact.
(image link here: https://s30.postimg.org/9pswq3t5d/post_1.jpg)
I agree there could be a lot of reasons for the sediment, but the main reason I think it is from spalled concrete and or other materials that weren't in the reactor, is because of the relatively low radiation levels the robot probe measured from it. TEPCO must have suspected this sediment could be from fuel fragments and on page 3 of the latest report, you can see they lowered the robots camera and dose apparatus almost directly onto the surface of the sediment but only recorded 6.3 sv/h.
(report link here: http://s16.postimg.org/4718oap51/Screenshot_2017-03-28-10-46-42-1.png)
I don't know enough to calculate the effects of the water shielding or the amount of time the fuel had to decay, but 6.3sv/h seems too low for the sediment to be made up of a fuel based component.
Likes Sotan
  • #1,204
That is an awesome photo Cire and it's been haunting me since last night :) Indeed that's almost how I picture what happened. (Maybe the flow was not quite as massive, but otherwise that's about how I imagine it...
And as Charles said, while in Unit 1 we don't seem to see enough evidence of such a catastrophic event, I too thought that Unit 2 looked close enough.
Does this mean you believe the RPV bottom was not pierced?
Also, as a layman, I find it very hard to explain to myself how water/steam could turn 100 tons of heavy melted stuff into dust and then carry it away.
If it did - what are the implications? Where is the corium? is it even possible to "remove the melted fuel debris"? All approaches until now appear to be based on the assumption that the corium is pretty much compact and mostly in one place.
  • #1,205
Since the matter relevant in reactor safety there were several experiments and simulations, so the process is more or less known. Compared to a slag dump, the main difference is that once the core material is relocated to the RPV bottom, the molten pool is around 1500-2500C (slag: 1000-1200C). So it's not that warm red, but shinning white.
Another difference is, that if it's under pressure then the first leaks are not like some spilling, but more like some laser from a wrong sci-fi movie. The kind, when you see the 'laser'. Kinda' like a cutting torch.
According to the known simulations, the whole core of U1 were relocated. The muon scanning seems to support this.
For the other two units, the simulations suggests only a partial relocation. I can't recall if they could find any sediment of the same kind there? If the sediment is missing that's another good clue.
Likes turi
  • #1,206
I believe there was probably some leakage of water/steam through the penetrations while the reactor was at pressure and overheating.
I think only a small portion of the fuel pellets where transported this way. I believe most are down at the base of the RPV.
A good place to go back too is the Three Mile Island accident. Here is a photo of the fuel rods after they failed.
Uranium fuel pellets that are aged and overheating will be highly fractured in their tubes. When the cladding fails you're not going to get a nice solid pellet dropping out, most likely you're going to get a crumbling bunch of fuel material spilling out. That material would be easily transported in a high velocity steam event.
Now here is a small steam boiler exploding.. Notice how much material and debris is transported. The dark colored steam is mostly the scale and junk from inside the vessel being ejected with the steam. You would only need to eject a very small amount of fuel to get the radiation readings we see today. This would also explain the odd readings in some places of the RPV.
Sotan said:
I don't believe the fuel pellets ever melted (in a corium context) at Fukushima. The cladding most certainly did. There will be lower temperature metals that did melt and mix with the pellets. Corium has only ever been seen at Chernobyl. Its a totally different reactor with different materials present.
Personally I think the safest way to clean the reactors is to dissolve the fuel and slurp out the radioactive byproducts then process that waste. I'd start by installing sprayers all around the RPV and inject an acid to dissolve the fuel/material and pump out the RPV as you go.
That's a grossly over simplified explanation. You would of course need to make sure that you where not leaking this soup out of the containment, etc.
Likes Dundeephysics and Sotan
  • #1,207
Thank you Cire. Very informative and interesting post!
Edit: Just noticed Tepco published some additional images resulted from enhancing the photos taken during the investigation of the PCV of Unit 2. Take a look:
http://photo.tepco.co.jp/date/2017/201703-j/170330-01j.html
Also, there is a short film which presents in summary the robotic investigation of Unit 1 PCV
http://www.tepco.co.jp/tepconews/library/archive-j.html?video_uuid=w870f623&catid=69619
(the animation at 00:47 insists on the "slag dump" supposition though.)
  • #1,208
Thanks Cire for two very common sense posts.
TIP tubes almost certainly melted which makes a path out of vessel to that equipment room, wherever it is in a BWR. They're small tubes, in my PWR less than 1/4 inch, but crumbled up fuel debris could get carried out of the vessel that way.
I don't recall seeing what is level of radiation in area of TIP drives.
  • #1,209
I was never under a BWR , just my PWR.
This, snipped from last one in Sotan's link, looks to me like small leaks have coated everything with sea salt. Had bottom of vessel melted one would expect those rod drives to be down on the floor ?
Likes Sotan
  • #1,210
After so much time, in that rainy environment?
I could not find any (serious)experiment/simulation where it's about a real control-from-bottom type reactor, but every other one suspects the break on the sides, where the curved bottom meets the cylindrical part.
Since U1-U2-U3 have plenty of additional cooling surface on the bottom (control rod penetrations/drives), I think this scenario is even more likely.
Cire said:
I don't believe the fuel pellets ever melted (in a corium context) at Fukushima. .
I hope it's you who is right, but the simulations so far proved to be pretty accurate.
  • #1,211
Yes. Boric Acid too, It makes a white crystalline deposit that looks a lot like this.
Immediately after the accident US military airlifted tons of boric acid to them.
  • #1,212
Hey Sotan,
Can you shed any light on what the gentleman in the short film is saying at the 1:10 mark? He seems to be talking about the pedestal doorway and the cube shaped hole in the pedestal floor.
  • #1,213
Hey Charles.
He's saying "It is presumed that the fuel from the RPV melted and fell inside this supporting structure (pedestal) and then, through openings such as these, spread into the space outside." It's just their working hypothesis.
- I also watched most of the 2h press conference on March 30th related to progress in the Mid- and Long term Roadmap. There were a few materials shown there some of which are not yet posted on the site (the enhanced photos of Unit 2 were posted but others not yet). They have new data on the operating floor of Unit 1, radiation readings of 100-200 mSv/h in most parts, except in the area of the well plug where the readings rise to 500-600 mSv. They inserted a sensor through the concrete plates that make up the well plug (which as you know have moved in the accident), and readings went up as high as 2 Sv/h.
- Also, they announced that they are ready to proceed today (March 31st) with the sampling of water+floating stuff from Unit 1 PCV, and they are trying to analyze some of the stuff that got stuck onto the tracks of the robot that drove on the gratings of Unit 2.
Edit: The new Mid and Long Term Roadmap Progress materials are posted here (in Japanese only for now)
http://www.tepco.co.jp/decommision/planaction/roadmap/index-j.html
Look for the section at the top that says "New" and "2017年3月30日".
  • #1,214
A few selections from those large files in the latest Roadmap progress update:
http://www.tepco.co.jp/nu/fukushima-np/roadmap/2017/images1/d170330_07-j.pdf (in Japanese)
- Page 7 (as given by Adobe Reader): this is hos they figure the operating floor of Unit 1 looks, assuming the rubble from the roof was removed. The FHM and its trolley are on the floor, the overhead crane is bent but hanging in, the well plug slabs look are displaced.
- Page 8-12: the well plug, before the accident and after. The photos are a bit hard to follow (I didn't have too much time). But the colored schemes show the present configurations (with approximation) of the blocks, as seen from various directions. If until now they had confirmed only the displacement of upper and middle layer of concrete slabs, now they can say that the lower layer has been displaced too.
- Pages 13-18: before, they had measured the radiation doses on the operating floor; this time they also inserted the sensor through the small openings among the well plug concrete slabs (the sensor went down as low as the lower layer of slabs, not further). Page 15 shows that the values are 113-130 mSv/h in areas unrelated with such openings, but rise to 443-512 mSv/h in the openings, showing - I think - that there is radiation coming from inside the well. Pages 17-18 show a sort of improvisation: they attached a radiation meter to a (what's the word) endoscope? that could be inserted between upper and middle layer of concrete. You can see on page 18 values rising as the tip of the endoscope was inserted towards the center of the well plug, up to 2.2 Sv/h.
- Pages 19-20 show an evaluation of the particle/grains of the dust on the operating floor (they want to avoid spreading such dust in the surroundings). 92% of those particles are 0.3~0.5 microns in size.http://www.tepco.co.jp/nu/fukushima-np/roadmap/2017/images1/d170330_08-j.pdf (in Japanese)
- From the last page - conclusions regarding the enhanced photos from Unit 2 PCV:
- By enhancing those photos they were able to extract further information regarding the extent of grating affected (fallen) as well as the degree of damage in PIP cables and other structures from the CRD housings.
- They found an additional panel of grating that has fallen, further back than what had been seen in the first evaluation - but also one panel that was confirmed to be in its original place, in an area not seen in the first evaluation.
- Cables or similar fallen objects can be seen traversing the open spaces formed where grating panels have fallen.
- TIP guide pipes appear to lay scattered on the grating.
- Not much damage in the structures located area above the CRD rails.
- In an area center-left of the pedestal (?) it was not possible to confirm the presence of PIP cables and LPRM cables. (They might be gone or could be there but are simply impossible to see in these photos.)
  • #1,215
I am curious about why did the operators in Unit 1 allow the isolation condensers to boil dry?
  • #1,216
I can only quote from two official reports as follows:
The IAEA report: http://www-pub.iaea.org/MTCD/Publications/PDF/Pub1710-ReportByTheDG-Web.pdf
P.34 "Just before the tsunami struck, the Unit 1 isolation condenser was stopped by the operators in accordance with established operating procedures to control the reactor cooling rate. This was accomplished by closing the valves (located outside the primary containment vessel and DC operated, as shown in Box 2.2). About 2.5 hours after the loss of indications, at 18:18 on 11 March, some of the status lamps for those valves were found to be functioning, confirming that the control valves were closed. The operators attempted to start the isolation condenser by opening those valves. However, the isolation condenser did not function, indicating that the AC powered isolation valves inside the primary containment vessel were closed.(Footnote 40) Thus, the fundamental safety function of core cooling at Unit 1 was lost when the isolation condenser was stopped by the operators just before the tsunami, and the Unit 1 core heated up from that time."
Footnote 40: The valve positions were not clear to the operators owing to the uncertain timing and sequence of each type of power loss that would determine the status of isolation valves. All the isolation condenser valves would keep their position when the AC power was lost, but the AC powered isolation valves would close, by design, if the control power (i.e. DC power) was lost.
P.56 "The isolation condenser (see Box 2.2) for cooling Unit 1 started automatically as the result of a high reactor vessel pressure signal. It opened the isolation valves in the condensate return lines (other isolation valves in the lines were open during normal operation) when the reactor shut down following the earthquake. As required by the operating procedures, the isolation condenser system was stopped and restarted several times by the operators to prevent the reactor from cooling down too quickly and causing thermal stress exceeding the reactor pressure vessel design values. This was done by opening and closing the isolation valves in the condensate return lines [8]. At the time the tsunami inundated the site and electrical power was lost, the operators had just stopped the isolation condenser system by closing a valve on the return line outside the primary containment vessel. Operators had no information available on the isolation condenser valve positions, and it was not until approximately three hours later that they first attempted to manually restart the isolation condenser. The operators were not fully trained to understand how the valves worked under these conditions. They ultimately made two unsuccessful attempts from the main control room to restart the isolation condenser by opening the outer isolation valves. The operators had no procedures to manually operate the isolation condenser. At the time of writing, the exact location of all of the valves in the isolation condenser system was unknown, but indications are that the isolation condenser did not function following the tsunami [8]."
P.72 "Operators at the Fukushima Daiichi NPP had not been specifically trained on how to manually operate systems such as the Unit 1 isolation condenser and fire trucks as an alternative source for low pressure water injection."
The report made by the Commission of the National Diet of Japan https://www.nirs.org/wp-content/uploads/fukushima/naiic_report.pdf
P.31 "5.The isolation condensers (A and B2 systems) of Unit 1 were shut down automatically at 14:52, but the operator of Unit 1 manually stopped both IC systems 11 minutes lat-er. TEPCO has consistently maintained that the explanation for the manual suspen-sion was that “it was judged that the per-hour reactor coolant temperature excursion rate could not be kept within 55 degrees (Celsius), which is the benchmark provided by the operational manual.” The government-led investigation report, as well as the government’s report to IAEA, states the same reason. However, according to several workers involved in the manual suspension of IC who responded to our investiga-tion, they stopped IC to check whether coolant was leaking from IC and other pipes because the reactor pressure was falling rapidly. While the operator’s explanations are reasonable and appropriate, TEPCO’s explanation is irrational."
  • #1,217
http://svcf.jp/pdf/Three_Mile_Iland2NP-6931.PDF
"The cleanup of Three Mile Island Unit 2: A technical history, 1979-1990"
If you read the above excellent document, you'd see what sort of problems arise when someone needs to remove damaged fuel from an *intact* RPV, on an *intact* plant. Nothing was easy. Even things which "had to be" relatively easy, weren't.
Removal at Fukushima would be some ten times harder, per each reactor.
As an example, the "dissolve everything with acid" plan would dissolve concrete foundation faster than it dissolves ceramic fuel pellets. Not good.
After reading TMI cleanup document, I'm firmly in the "these ruined reactors do not need cleanup, they need cocooning a-la Hanford" camp.
  • #1,218
We have plenty of concrete there. We can afford to dissolve a bunch of it if needed. The fuel / fragments have much higher surface area per volume then the foundation does. You could also pre-treat the foundation concrete with a rubber sealer like Kalrez from DuPont or a Silicone.
A spray on Silicone works great because you can later come back and peel off that thick layer and take with it any particulate it managed to embed when it was applied.
Here are some patents on the process.. There are many ways to go at it.
https://www.google.ch/patents/US20030092954
https://www.google.ch/patents/US5523513
A good read:
http://www.cresp.org/NuclearChemCou...el Cycle Separations - Final rev 2_3_2_09.pdf
  • #1,219
However, concrete is noticeably dissolved even by "weak", household-grade acids, whereas many kinds of ceramic are not. Reprocessing uses concentrated nitric acid to dissolve spent fuel - I don't think you propose to pour *that* into the PCV?
You could also pre-treat the foundation concrete with a rubber sealer like Kalrez from DuPont or a Silicone&
You cannot pre-preat foundations inside PCV. It's no-go for humans (rad fields of several Sv/h), and robots won't do, they are far too clumsy.
  • #1,220
Nitric acid seems completely appropriate for the job. The RPV itself is clad in stainless steel (308/309) and most of the internal plumbing is inconel. Both are resistant to Nitric acid. You simply control the dissolution rate of the fuel debris by varying the concentration of the acid.
I would start by washing the external surfaces in the dry well, pedestal and other area to dissolve and remove as much external material as possible, thus lowering radiation levels around the RPV. I'd then pump out the suppression wet well and treat it next.
Once done I'd switch to injecting directly into the RPV and work via the drains; trap and extract whatever leaks out of the bottom.
The more fuel and actinides you can remove the lower the radiation and the easier it becomes to send people to work in those areas.
There are no engineering problems here that aren't solvable.
  • #1,221
Sure, inside surface of the RPV is okay.
Are _other surfaces_ okay? Like, the inner surface of the PCV? The basement of PCV?
For starters, _how_ would you do that? You cannot send people into PCV, you need to do it with robots. And god forbid a robot would break while inside, or just tip over, be caught in the piping, or otherwise unable to exit. Now you need to dissolve the robot too.
As to "removing material", yes, you can achieve quite a bit of that with acid. The material in question would be, foremost, concrete floor and basement walls. Not good.
Correct. As long as cost and schedule are completely ignored.
BTW, looks like you did not read the TMI cleanup document. Please do that.
Especially section "7.4.3 Containment basement" - it's an eye-opener.
They needed to clean up a basement polluted "merely" by the radioactive primary loop water - not a single gram of solid fuel made it out of RPV during TMI accident. Should not be too difficult, right? "There are no engineering problems here that aren't solvable".
So, take a guess. Did TMI cleanup operation succeed in cleaning up TMI-2 containment basement?
  • #1,222
This job is not exclusively for nitric acid.
https://en.wikipedia.org/wiki/In_situ_leach#Uranium
I dare to say that there might be 'concrete-friendly' choices. The real problem - I think - is that nobody tried this technology with corium and/or heavily contaminated mixed materials and nobody wants to invest in a new technology which will be used only once.
  • #1,223
There was fuel material on the containment floor at TMI. Not melted through the vessel, but gaseous and transported fuel pellet fragments.
Remember a relief valve was stuck open, and cladding failure occurred while the relief valve was open. This allowed for transport of pellet fission products out to the pressurizer relief tank, which had a blown rupture disc, and allowed those fission products to transport to the containment itself where containment sprays would have relocated it to the floor.
  • #1,224
Yes, at TMI-2 fission products were transported outside RPV - in forms such as salts, vapor (iodine) and gases (Kr, Xe). But not macroscopic (say, millimeter-sized) bits of fuel ceramic. PRV on pressurizer is rather far away from the RPV.
Compared to the state of Fukushima reactors, TMI-2 cleanup is very easy. Yet, even it was actually quite difficult in real life, and containment basement was eventually left not cleaned up - after years of work they finally admitted it does not make sense: too much work and and too many $$$ for questionable gains.
  • Earth Sciences
14K
4M
  • Nuclear Engineering
46K
16K
  • Earth Sciences
259K
