T: Lorentz Transformation for Length and Relativistic Mass
To determine the speed at which length contracts by a factor of 2 according to the Lorentz transformation, one must set the Lorentz factor, γ, equal to 2, leading to a speed of approximately 0.866c. At this speed, an object's relativistic mass increases according to the formula m = m0/√(1-v²/c²), where m0 is the rest mass. The discussion emphasizes that while relativistic mass appears to increase for an observer at rest, it does not change in the object's own frame. Clarification on the difference between rest mass and relativistic mass is also highlighted as crucial for understanding the problem. This topic illustrates key concepts in special relativity, particularly length contraction and mass increase.
kathykoo9
Using the Lorentz transformation, at what speed relative to speed of light c must you travel so that your length along the direction of motion is seen to decrease by a factor of 2? For this speed, hwo much would your mass be increased?
Please show steps, I'm confused with this question!
first of all my dear friend, this is the wrong forum...
second, show us what you have tried so far - otherwise it is pointless and there is always a suspicion that this is homework.
Can you write out the Lorentz transformation for distance co-ordinates in two frames whose relative speed is v?
You are moving at speed v relative to an Earth observer, say.
Let one end of your length be at x=0 at time t=0 and let the other end be at x = L at time t=0 in your frame. Use the Lorentz transformation to translate those co-ordinates to the Earth observer's frame.
It is not considered correct to say that the mass increases. It certainly does not increase in your frame. Relativistic (apparent) mass may increase for an Earth observer and this is probably what you are being asked to find. Do you know the relationship between rest mass and relativistic (apparent) mass?
AM
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
