M-How to calculate force on a surface due to a beam of particles?
  • Thread starter Thread starter debwaldy
    Flux Force
The discussion revolves around calculating the force exerted on a surface by a beam of helium atoms. The key points include understanding beam flux as the number of atoms per square meter per second and its relation to the surface area. Participants clarify that the change in momentum during collisions and the rate of change of momentum are essential for determining the force. The mass of a helium atom is necessary for calculations, and the z component of the beam flux is relevant for determining the number of collisions per second. The conversation emphasizes using the formula for change in momentum to derive the force acting on the surface.
debwaldy
hi,so iv been trying to work out this problem but I am stuck because i don't understand what the lux in the question is,could anyone explain it to me?
the question says:
a beam of helium atoms is incident at an angle of 60 degrees on a flat surface of area 0.2 m^2. each atom has a velocity of 3* 10^7 m s^-1 and the beam flux is 10^16 atoms m^-2 s^-1.assuming the beam covers the whole surface what is the force on the surface?
im guessing beam flux is perhaps the intensity,or the amount of atoms which wud pass through 1m^2 of surface in one second?and how exactly could i relate this to the question?should i multiply it by 0.2m^2 to figure out how many wud pass through the surface area in the question in one second?
any hints or direction would be greatly appreciated:smile:
debwaldy said:
the question says:
No guessing about it. That is what it is.
Assume that the He atoms collide elastically with the surface. What is the momentum imparted to the surface by one collision? (what is the change in momentum of the He atom in the collision?) What is the rate of change of momentum (ie change of momentum per unit time)? How is that related to the "force"?
AM
thanks..so do i need to know the mass of a helium atom to answer this question?
so far iv said: the change in momentutm = (3.0*10^7)(mass of he atom)(sin60)(2)=5.1961*10^7(mass of he atom)
according to my book the rate of change of momentum= (z component of momentum)( z component of velocity)/(height)
the height of what though?how do i relate this to the area i am given?
and do i need to get the z component of the beam flux for my calculations,or do i just multiply the beam flux by 0.2m^2 to get the amount of atoms that pass through 0.2m^2 in 1 sec?
I am not sure what the height refers to but would appear to have nothing to do with this problem.
Yes. Just work out the change of momentum per second. How many of these collisions occur per second on this area?
Or more formally:
\Delta p = 2mv\sin\theta
Since the speed and angle do not change:
\frac{dp}{dt} = 2vsin\theta \frac{dm}{dt}
What is dm/dt (the mass flow per unit time) striking this surface?
AM
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
