What Happens to a Proton in a Magnetic Field?
A proton moving at a speed of 3.7 x 10^6 m/s in a magnetic field of 0.45T experiences a magnetic force calculated using the formula F = qvB, resulting in a force of 2.67 x 10^-13 N. The radius of the circular motion is determined using r = mv/qB, yielding a radius of 0.086 m. A diagram was provided to illustrate the directions of velocity, magnetic force, and magnetic field, but it was noted that the magnetic force should be perpendicular to the field. Overall, the calculations for force and radius are confirmed to be correct. The discussion emphasizes the importance of understanding the orientation of forces in magnetic fields.
shanie
A proton with the speed 3.7*10^6 m/s is moving in a magnetic field, parallel to the field.
The magnetic B-force is 0.45T.
a)Draw a figure that shows the proton in the magnetic field. Indicate the direction of the proton's velocity, the direction of the magnetic field and the direction of the magnetic force.
b) Determine the magnetic force.
c) Determine the radius of the circular motion that the proton will make.
a) Using the right hand rule
b) F= qvB
c) r= mv/qB
a) The picture I drew looked like this
http://img134.imageshack.us/img134/3895/namnls1hx8.png
where v is the direction of velocity, Fm the magnetic force and the B-force is the cross going into the paper.
b) F = (1.602*10^-19)*3.7*10^6*0.45=2.67*10^-13 N
c) r=mv/qB=[(1.673*10^-27)*(3.7*10^6)]/[(1.602*10^-19)*0.45]
r=0.086 m
Could anyone tell me if this is correct? I would really appreciate some help!
A proton with the speed 3.7*10^6 m/s is moving in a magnetic field, parallel to the field.The magnetic B-force is 0.45T.
It should be perpendicular to the field.
Rest of the calculation is correct
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
