Magnitude of Acceleration after initial impulse?
The discussion revolves around a physics problem involving a block on an incline, focusing on the calculation of acceleration after an initial impulse in two scenarios: moving downhill and uphill. The problem includes parameters such as mass, incline angle, and coefficients of friction.
  • The original poster attempts to apply equations related to forces and acceleration but expresses uncertainty about the correctness of their calculations. Some participants question the interpretation of the magnitude of acceleration and suggest a focus on the forces acting on the block.
Participants are exploring different aspects of the problem, particularly the implications of direction changes in forces when the block moves uphill versus downhill. Guidance has been offered regarding the application of Newton's second law and the need to consider the direction of forces.
There is an indication of confusion regarding the application of equations and the interpretation of results, particularly in relation to the sign of acceleration when the block moves in different directions. The original poster has not yet resolved the calculations for the uphill scenario.
jumpingjack90
A block with a mass of m = 3.04 kg is at rest on an incline. The angle of the incline is θ = 20.3° with respect to the horizontal. The coefficient of static friction between the object and the incline is μs = 0.645, the coefficient of kinetic friction is μk = 0.449.
a.) What would be the magnitude of the object's acceleration after an initial impulse set it in motion downhill on the incline?
b.)What would be the magnitude of the object's acceleration after an initial impulse set it in motion uphill on the incline?
F=(uk)(mg)(cos(theta))
ma=mgsin(theta)-mg(uk)(cos(theta))
I have no idea what to do. I tried using the above equations and found that
a=(3.04)(9.8)(sin(20.3))-(9.8)(3.04)(cos(20.3))(0.449) / (3.04) = -0.726 m/s^2 which is the wrong answer. ?
Looks OK to me. Are you sure you gave the magnitude of the acceleration?
ok. found the answer to part 1. How do you do part 2 when the block is traveling uphill?
Identify the forces acting on the block, then apply Newton's 2nd law. (That's how you should solve part 1 as well. That way you know how to derive the formula for acceleration.)
What Doc is saying is, if you look at the forces involved, one of them has changed its direction and therefore its sign. If you just try to plug into equations you were given, you won't see that.
