Maximum theoretical and experimental stress in T-beam.
This discussion focuses on calculating the maximum theoretical and experimental stress in a T-beam using strain gauges. The primary equation utilized is σ = My/I, where M represents the bending moment, y is the distance from the neutral axis, and I is the second moment of area. Participants emphasize the importance of determining the neutral axis location and calculating the maximum bending moment based on the applied loads. The conversation also highlights the need to compare experimental strain readings with theoretical predictions to validate results.
  • Understanding of T-beam cross-section dimensions and properties
  • Familiarity with strain gauge measurements and data collection
  • Knowledge of bending moment calculations and beam theory
  • Proficiency in using the formula σ = My/I for stress calculations
  • Calculate the second moment of area I for the T-beam cross-section
  • Determine the location of the neutral axis for the T-beam
  • Analyze the bending moment distribution along the beam under various loads
  • Compare experimental strain data with theoretical predictions to assess accuracy
Structural engineers, civil engineering students, and researchers involved in beam stress analysis and experimental mechanics will benefit from this discussion.
SherlockOhms
1. Take dimensions of the beam (B, D, web and flange thickness, L) – T- cross section
2. Take the beam span geometry and material properties from the instrument
3. Ensure the beam and load cell are properly aligned and apply a positive (downward) preload to the beam of 100N. Zero the load cell using the control.
4. Take zero readings for all 9 gauges.
5. Increase load to 100N and take note of the readings. Repeat procedure in 100N increments to 500N
6. Gradually release the load and preload and correct strain reading values
7. Convert the load to a bending moment
8. Plot a graph of strain against bending moment for all 9 gauges (on one graph)
9. Calculate the average strains from the pairs of gauges, where applicable
10. Plot a graph of strain against gauge position using T beam cross section
11. Locate experimental neutral axis and compare with theoretical
12. Calculate and compare maximum experimental and theoretical stress
##\sigma = \frac{My}{I}##
So, this was an experiment in which there were strain gauges set up along a T-beam and we were asked to measure the strain at various different points whilst applying different loads. Could someone tell me how I go about calculating the maximum theoretical stress? Is it by the equation: $$\sigma = \frac{My}{I}$$ where M is the moment about the neutral axis, y is the displacement (in this case it'll be the maximum distance allowable from the neutral axis) and I is the second moment of area? I have absolutely no clue how to calculate the max experimental stress. Any hints/tips?
Also, I'll attach a picture of the T-beam (a miniature version with the dimensions).
The flange and web width are 6.4.
The length is shown in the diagram on the left.
From your graph you would get the maximum strain which would correspond to the maximum stressed area.
For the theoretical max stress, you would need to calculate I for the T section and find the location of the neutral axis (remember how to find centroids?). From the loading conditions, you would also need to find the maximum bending moment and where it occurs.
So, is your first part for the max experimental stress? Like, I find the max stressed area and then divide the maximum load by this? I'm not sure if I follow.
Well, the loads act at along the beams length, 350 mm from the ends. So, the bending moment will be -W/2 x 0.35? I've already calculated ##y_{theoretical}## and ##I## for the T-section. So, would I just sub in, the maximum distance from ##y_{theoretical}##, ##I## and -W/2 x .35 into my equation for bending stress?
24K
23K
