ME 354 Mechanics of Materials Laboratory
The discussion focuses on the ME 354 Mechanics of Materials Laboratory course at the University of Washington, covering essential topics such as stress, strain, and constitutive relations, as well as beam analysis and mechanical properties of materials. Key chapters include the study of curved and composite beams, stress concentrations, fracture mechanics, and time-dependent behaviors like creep and cyclic fatigue. The course also addresses compression, buckling, and the analysis of pressure vessels using finite element analysis (FEA). Participants express appreciation for the course notes, highlighting their usefulness for understanding complex material behavior. Overall, the thread emphasizes the value of the course content for mechanical engineering students.
Astronuc
Staff Emeritus
University of Washington - Mechanical Engineering Department
Course Notes
Chapter 1 Introduction
Chapter 2 Stress, Strain and Constitutive Relations
Chapter 3 Beams: Strain, Stress, Deflections
Discontinuity functions
Comparison of disc. functions and FEA
Beam deflection examples
Chapter 4 Beams; Curved, Composite, Unsymmetrical
· Curved beams
· Unsymmetrical beams and angle section properties
Chapter 5 Mechanical Properties and Performance of Materials
· Plasticity relations
· Strength theories
Chapter 6 Stress Concentrations and Stress Raisers
Chapter 7 Fracture
Chapter 8 Time Dependant Behavior: Creep
Chapter 9 Time Dependant Behavior: Cyclic Fatigue
· Data for fatigue design calculations
Chapter 10 Compression and Buckling
· FEA examples
Chapter 11 Structures, Complex Stresses and Deflections
· Energy methods
Chapter 12 Pressure Vessels
· Thin walled vessels
· Thick walled cylinders
· FEA derived stress distributions
· Shrink fit example
References
Great link ... thanks ! I'll be passing this along.
Yay UW represent!
Yes those lecture notes were indeed helpful!
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
