Mechanics of materials question, angle of twist in shaft
The discussion centers on understanding the angle of twist in shafts, specifically regarding the internal torque and its calculation. The internal torque is derived from a distributed torque function, with the slope of torque distribution calculated as 25 kNm/m². The confusion arises from the integration process, where the total torque is expressed as (1/2)*(25 x²) kNm, leading to a further integration resulting in (1/6)*(25 x³) kNm. The participant questions the logic of this last integration step, suggesting a possible error in the book's solution. The conversation highlights the complexities of torque distribution and the integration involved in determining the angle of twist.
davidhansson
Hello, I'm studying machanics of materials.. I'm at the chapter that handles the angle of twist in shafts. There's one exercise that I get the most part of, but there's just a tiny part of it that I don't get!
here's the exercise: http://davidhansson.deviantart.com/art/Wp-20131015-001-407472489
and here's the solution from the book: http://davidhansson.deviantart.com/art/Wp-20131015-005-407472644
what I don't get, is what internal torque really means and how it become (1/2)*25x*x ,,
Where does the "(1/2)" comes from, and where does the extra x comes from..
My intuition is that it should be integrated like: 1/((pi/2)*75*10^9) ∫(15000/0.6)*x integration from 0 to 0.6 ,, which would be the twist in radians for the part AB.
I apologies if it's hard to understand
lot's of thanks/ David Hansson
It's tricky to explain, but I'll have a go.
The value of 15 kNm/m at point A is not the torque at A but the change in torque per unit length of the shaft from that point. Since the torque is zero at B, the slope of the torque distribution = 15 kNm/m divided by 0.6 m = 25 kNm /m^2. To calculate the value of the distributed torque at at distance x from point B, then
t(x) = 25 kNm/m^2 * x m = (25 x) kNm/m
The total torque applied would be the integral of the function t(x) from x = 0 to x = 0.6 m, so
T = (1/2)*(25 x^2) kNm
It's a weird way to express the torque distribution and I can understand your confusion.
Hello, lots of thanks for the reply!
What you're saying sounds fully logic and was also my intuition. The weird thing though is that they make one additional integration to the (1/2)*(25 x^2) kNm ,, so we get (1/6)*(25 x^3) kNm (from 0 to 0.6).. and then multiply with the constants ofc,, this will give the final answer: 0.00895 rad that's written in the book. To me, this last integration feels totally unlogical, could it be that they actually have made a mistake in the book?
thanks/ David
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
