How Does Equilibrium Apply in Calculating Forces on a Sphere and Rod System?
  • Thread starter Thread starter jiayingsim123
    Mechanics Moments
The discussion focuses on calculating forces in a system involving a uniform sphere and a rod in equilibrium. The sphere, with a weight of 36N, is in contact with a horizontal plane and a rod that weighs 14N. The key point is that taking moments about point C allows for the determination of the normal contact force at point A as 10N, while moments about point O help establish that the frictional forces at points A, B, and C are equal. Clarifications are sought regarding why certain forces are not included in the moment calculations, emphasizing that only relevant forces that contribute to torque should be considered. The conversation highlights the importance of understanding the equilibrium conditions and the role of friction in maintaining stability in the system.
jiayingsim123
A uniform sphere rests on a horizontal plane. The sphere has centre O, radius 0.6m and weight 36N. A uniform rod AB, of weight 14N and length 1 m, rests with A in contact with the plane and B in contact with the sphere at the end of a horizontal diameter. The point of contact of the sphere with the plane is C, and A, B, C and O lie in the same vertical plane (see diagram). The contacts at A, B and C are rough and the system is in equilibrium. By taking moments about C for the system,
(i) show that the magnitude of the normal contact force at A is 10N.
(ii) Show that the magnitudes of the frictional forces at A, B and C are equal.
http://papers.xtremepapers.com/CIE/Cambridge%20International%20A%20and%20AS%20Level/Mathematics%20-%20Further%20(9231)/9231_s09_qp_2.pdf
The diagram can be found in this link, question no.4.
I know that if the system is in equilibrium, then the resultant force in any direction and the sum of moments about any point is zero. What I don't get about sub-question (i) is: there is a reaction force acting at point B, and friction as well acting at the same point (due to the surface being rough), but why are we not required to take moments about point C for those forces? Why do we only take moments about point C for the weight of the rod and the reaction force at A? As for question (ii), the worked solution I have is that by taking moments about point O, we can prove that the frictional force at B is equals to that at C, but why isn't the frictional force at A taken into account when taking moments about C - the line of force for that friction does not go through C though!
Here is the link to the worked solutions for both sub-questions:
http://papers.xtremepapers.com/CIE/Cambridge%20International%20A%20and%20AS%20Level/Mathematics%20-%20Further%20(9231)/9231_s09_ms_2.pdf
(Question 4)
Thanks! I'd really appreciate if you could explain the worked solution for me! :)
Everything apart from the weight of the rod and the normal component of the force of A has a matching force in the opposite direction at the same point (B) of the force points towards C (so its corresponding torque is 0 independent of the force - happens at A and C).
It does, it is in the plane.
Hi there, thanks for replying.
So what you're trying to say is that at B, there is frictional force acting both downwards and upwards (upwards on the rod to prevent it from sliding down and downwards on the sphere presumably?). And there is a reaction force acting on the rod because the rod is leaning against the sphere, so everything cancels out in a way? By that logic, can't we say that at A, there's a reaction force on the plane by the rod as well? Or is that represented by the weight already? Sorry, I'm just trying to verify my understanding - I've been stuck on this question for quite some time now. :p
As for question (ii), sorry I didn't mean moments about C, I meant moments about O instead. The frictional force at D doesn't go through O though right? But why is not taken into account as suggested by the worked solution?
Thanks for your patience!
Right.
The floor is not included in your system., so you shouldn't consider forces acting on the floor if you want to calculate torque in your system.
Where is D? Do you mean A?
The moments for O are considered to exclude a rotating sphere only.
Hi I'm so sorry, yes I do mean at A. What do you mean by that last statement? Doesn't the frictional force act perpendicularly to the line connecting O to C?
You want that the sphere does not rotate around its center. Therefore, the sum of torques acting on the sphere has to be 0. There are two: Friction of the rod and friction on the ground.
