Moment of Inertia of Cavendish pendulum
The discussion focuses on calculating the moment of inertia for a Cavendish pendulum, initially using the formula I = 2(m r^2), which is appropriate for a dumbbell configuration. Participants clarify that the moment of inertia should also account for the suspension mechanism and the weights of the bar and wire. A revised formula is proposed, incorporating the moment of inertia for a rod rotating around its midpoint, resulting in a total moment of inertia calculation of approximately 13,137,851.84 cm² g. Diagrams from Cavendish's original paper are shared to illustrate the pendulum's geometry. The final consensus indicates that the calculations and considerations presented are on the right track.
Pioneer1
Hi,
I am trying to compute the moment of inertia of the Cavendish pendulum. I used
I = 2(m r^2)
r = gyration arm
m = the weight attached to the pendulum
But this formula is for a dumbell type of torsion pendulum where the weights are attached to the bar.
Does anyone know the formula for a pendulum where the weights are suspended as in the case of the Cavendish pendulum? I couldn't find it online.
With this formula I got
I = 2 ( 729.8 * 93.1^2) = 12,651,243.56 g cm^2
Does this sound right for a pendulum of this dimensions?
Thanks for your help.
For the benefit of those of us who haven't been following your previous discussions closely, can you provide a diagram of the specific geometry that you have in mind, so we can see how it differs from Example 1 in the link you provided (which is the case where I = 2mr^2)?
Thanks for your reply. Here's the drawing from Cavendish's original paper:
http://www.alphysics.com/cavendishexperiment/CavendishSchematic11.jpg
And here's a detail
http://www.alphysics.com/cavendishexperiment/CavendishSchematic111.jpg
Cavendish also gave the weight of the bar and the silver wire he used to strengthen it. I assume those will have to be taken into consideration as well.
You've still got two masses revolving around a common central point, so their moment of inertia I is the same as when they're connected by a rod of negligible mass in a dumbbell configuration as in the page you first referenced. So you're OK so far.
What you need now is I for the rotating part of the suspension mechanism. You have the mass of the transverse rod, and I for a rod rotating transversely around its midpoint is a standard case. For some reason it's not on the page you first referenced, but you can find it on Hyperphysics:
http://hyperphysics.phy-astr.gsu.edu/hbase/mi.html#cmi
Just add the two I's together. In principle, you should also consider I for the rest of the rotating part of the apparatus, but the supporting wires are probably pretty light so you can safely neglect them, at least as a start in your analysis.
Ok. Thanks. From hyperphysics I got 1/12 M L^2 and added it to the previous result:
I = 2 m r^2 + 1/12 M L^2
L = length of the rod
r = half length of the rod
So,
Total moment of inertia for the Cavendish experiment = r^2 (2m + 1/3M) = 13,137,851.84 cm2 g
m = weight of each ball = 729.8 g
M = Rod weight = 155.5 + 11 + 2.9 = 169.40 g (including deal rod, silver supporting wire, vernier attached to the arm)
L = Rod length = 73.3 inches = 186.18 cm
r = Half rod length = 93.09 cm
I also added another picture with a little more detail about the arm. (Figure 3 here.)
Does this look good?
Thanks again for your help.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
