Momentum perturbation to harmonic oscillator
m1rohit
the problem and a possible solution(obtained from a book) is attached as a pdf to the post.However Iam unable to understand it.Please download the attachment.
equation no (2) in the pdf.Is there any use of space translation operator in here.
I have solved this problem using perturbation theory.however Iam intrigued by the method used here.
It can be understood using the properties of the Fourier transform. Since x and p are canonically conjugate, transformation from \psi(x) to \psi(p) is done by a Fourier transform. And from their properties, it is known that shifting the zero in one variable will be equivalent to a complex phase shift in the other.
Thank you very much for your reply.can you refer me any link or book where i could get problems on translation operators.
I don't if it's the right level for you, but you can take a look at W. Greiner & B. Müller, Quantum Mechanics: Symmetries (Springer).
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
