Mastering Net Ionic Equations: Easy Tips and Common Mistakes to Avoid
  • Thread starter jhs1st
  • Tags
    Ionic Net
In summary, the conversation discusses difficulties with writing net ionic equations and includes several sample problems with the corresponding answers. Tips are given for writing ionic equations, including breaking everything down to ions and identifying spectator ions. Common mistakes, such as forgetting to include charges on ions or not considering specific rules for certain reactions, are also mentioned. The conversation ends with a reminder to not get discouraged by incorrect answers as predicting reactions can take time to learn.
jhs1st
Net Ionic Equations! Please help me out!
i'm having a hard time with writing net inoic equations and here are some sample problems with the answers I came up with.
Please look over them and if somethings wrong, please correct the errors teach me how to fix it.
1. A strip of copper is immersed in dilute nitric acid
Cu + HNO3 -> Cu(NO3)2
2. Excess concentrated ammonia solution is added to a suspension of silver chloride.
Ag+ + OH- -> AgOH
3. Solution of tri-potassium phosphate and zinc nitrate are mixed
3Zn+ + (PO4)^-3 -> Zn3PO4
4. Concentrated hydrochloric acid is added to solid manganese (II) sulfide.
Mn^+2 + Cl2- -> MnCl2
and the rest of them below, I had no clue on how to even start
1. Potassium permanganate solution is added to an acidic solution of hydrogen peroxide
I got KMnO4 + H2O2 -> KMnO4 + H + O2^-2
but i hit the wall right here...
I'm guessing that the product is HMnO4 but I'm not confident at all.
2. Excess chlorine gas is passed over hot iron filings
Cl2 + Fe^2+ ? sorry..but i couldn't figure this one out either
3. Water is added to a sample of solid magnesium nitride
4. Excess sulfur dioxide gas is bubbled thru a dilute solution of potassium hydroxide
p.s. thank you so much for reading this. But if you have an extra time, would you give some tips on writing an ionic equations? or list some most common mistakes that students make when they first learn this?
Im assuming this are for precipitate reactions and not redox... if this is the case this might help. http://www.ausetute.com.au/ppteeqtn.html
Break everything down to ions except the solid precipitate on the resultant side, then you know what your spectators are. Hope this helps
Steve
no...looks like there are some redox reactions in there too. Those last couple are definatly redox.
for #4, where did you get the Cl2-? Concentrated hydrochloric acid solution is H+ + Cl-.
I think that "Most chloride, bromide, and iodide salts are soluble with the notable exeptions of salts containing the ions Ag+ Pb2+ and Hg2+.
for the potassium permanganate one, a good rule to follow is that potassium permanganate is almost always a catalyst, and does not change, but your hydrogen peroxide will speed its way into decomposition into water and oxygen gas.
On the first #1, there is a specific rule for thes reaction which is "Copper reacts with DILUTE nitric acid to produce copper(II) nitrate, nitrogen monoxide, and water.
I'm not sure about the chlorine and iron one or the water and magnesium nitride one.
I can find no error in the rest of them, and please don't take it hard that some of your answers are not correct. It took me about a year to learn how to predict reactions to the ability that i can now, and obviously I still can't do them all. They are really tough.
When i posted i don't even think those were there. I know there is no edit but i never saw those. But you are right those are definitely redox.
1. What is a net ionic equation?
A net ionic equation is a chemical equation that only includes the species that participate in a reaction. It shows the actual chemical change that occurs, rather than including spectator ions that do not undergo a change.
2. How is a net ionic equation different from a regular chemical equation?
A regular chemical equation shows all of the reactants and products involved in a reaction, while a net ionic equation only includes the species that are directly involved in the reaction. It simplifies the equation and shows the essential components of the reaction.
3. Why is writing net ionic equations important?
Net ionic equations are important because they show the actual chemical change that occurs in a reaction, making it easier to understand and analyze the reaction. They also help to identify the important species involved and their relative quantities.
4. What are spectator ions?
Spectator ions are ions that are present in a reaction but do not undergo a chemical change. They are found on both the reactant and product side of a chemical equation and do not affect the overall outcome of the reaction.
5. How do you balance a net ionic equation?
To balance a net ionic equation, you must first write the balanced molecular equation, then determine the net ionic equation by eliminating spectator ions. Finally, balance the net ionic equation by adjusting the coefficients to ensure that the number of atoms on each side of the equation is equal.
24K
31K
