Please help with refraction problem (algebra-based physics)
  • Thread starter Thread starter mirracle4
    Physics Refraction
The discussion revolves around a problem involving the refraction of light as it passes from water to air, specifically analyzing the angles of incidence and refraction in a swimming pool scenario.
  • The original poster attempts to calculate the angle of incidence using the tangent function and applies Snell's Law, but encounters a domain error when trying to find the angle of refraction. Participants question whether the angle of incidence is measured from the surface or the normal.
Some participants provide guidance regarding the domain error, suggesting that it may arise from incorrect input values. There is acknowledgment of a common mistake regarding the measurement of angles, and the discussion hints at the concept of total internal reflection as a potential issue in similar future scenarios.
The problem is constrained by the need to apply Snell's Law correctly and the understanding of angle measurements in the context of refraction.
mirracle4
A flashlight on the bottom of a 4.10 m deep swimming pool sends a ray upward and at an angle so that the ray strikes the surface of the water 2.25 m from the point directly above the flashlight. What angle (in air) does the emerging ray make with the water's surface?
I attempted to find the angle of incidence by using the lengths given and the arc tangent function and then to plug it into Snell's Law (n1sinθ1 = n2sinθ2).
For the angle, I got 61.2 degrees by doing "inverse tan(4.10/2.25)." However, when solving Snell's Law for θ2 and plugging in all of the values, the calculator keeps saying "domain error." I'm plugging in... "inverse sin((n1sin61.2)/1.00) and I keep getting the error message. Please help!
Hello mirracle4. Welcome to PF !
Domain error, no doubt, results from you asking the calculator to find the arcsine of something greater than 1.
Is angle of incidence measured from the surface, or from the normal to the surface?
Is angle of incidence measure from the surface, or from the normal to the surface?
Thanks SammyS! I got it right this time. I should have known that the angle I was using was the angle measured from the surface rather than the normal but somehow it slipped my mind.
It's good that you got it right now.
It's a mistake that I think we all have made some time or other. By the way, if in the future you have that domain error with Snell's Law, but you have done everything correctly, it's likely that it's a situation involving total internal reflection.
Good to know :smile:
