Plumb a Tree w/240 N Force: Find & Fix Incorrect Answer
  • Thread starter Thread starter formulajoe
    Force Tree
A landscaper is attempting to plumb a tree by applying a 240 N force at a 30-degree angle, while two helpers are trying to achieve the same effect with forces at points B and C. The tree leans 20 degrees to the right, with point B positioned 0.35 m above point A and point C 0.25 m below. The discussion emphasizes the need to express the force vectors in i, j form for clarity. Participants suggest providing a visual representation of the setup to better understand the forces involved. The original poster is encouraged to share their calculations for further assistance.
formulajoe
a landscaper tries to plumb a tree by applying a 240 N forces. two helpers attempt to plumb the same tree with one pulling at point b and the other pushing with a parallel force at point c. determine these two forces so they are equivalent to the single 240 N force. the force is at point A. it is coming in at a 30 deg angle. this force is on the right. the entire tree is leaning to the right 20 deg. point b is .35 m above point a. point C is .25 m below point A. I am getting some answers but they arent right. what do i do??
Show us what you did, and then we can help. Specifically, it would help if you write the force vectors in i, j form, because I for one am getting a fuzzy picture from your verbal description.
if you have access to a digital camera you can take a picture of it and then host it online. i usually do this because it is hard to decipher what is going on without a picture.
-andrew
