Solving the Pulley Problem: Find a & T
The discussion focuses on solving a pulley problem involving two masses, where the goal is to find the acceleration and tension in the system. The equations of motion are derived, with the net force on the hanging mass expressed as mg - T = ma, while the force on the other mass is T = Ma. Participants clarify that the acceleration is positive when the system is moving downward, as gravity is acting in the same direction as the motion. There is confusion regarding the signs of the equations, but it is emphasized that assuming the correct direction for acceleration is crucial for arriving at the right solution. Understanding the relationship between tension and gravitational force is key to solving the problem correctly.
blackrose01
pulley problem :D
Find the acceleration and tension of the system.
there were no values given so i assumed that our teacher wants the answer in terms of m, M, g, a, T, F.
http://img202.imageshack.us/img202/8615/picture1gz.th.jpg
Uploaded with ImageShack.us
F=ma
F=ma
T = F ----> where the F = (mass of hanging block)g
i still don't know about the acceleration though
No, T is not equal to mg.
The mass 'm' has force 'mg' acting downwards, T acting upwards, and it accelerates downwards.
So,
mg - T = ma (net F = ma)
Mass M has just one force, T acting on it.
So,
T = Ma.
You can solve these two equations for T and a in terms of m, M and g.
I recently had a question simillar to this on an exam and got it wrong for some reason. I figure the the EQ of motion for the hanging block would be T-mg=-ma, the answer is obviously the one which graphene gave but I don't understand why. The way I visualized this problem was there is tension acting opposite to gravity but my system is accelerating downward so I should, or so I assumed, have a negative acceleration component. Why is this not the case? I see that if I divide my answer through by a negative I get the correct answer, but this is merely an algebraic trick, it doesn't appear to change anything. Thanks in advance.
Joe
Joe
mg-T=ma
this is because the blocks are accelerating and not decelerating.
If you understand this then you can see that acceleration of the block is positive because if is negative. Also mg > T because it is moving downwards.. With knowns your equation would be positive, and just isn't simplified.
Do not put any sign on 'a'. Let it just be 'a'. Assume a direction for 'a' and write down Newton's 2nd law. (Net force in the direction of 'a' = ma).
In case you assumed the correct direction for 'a', you'll get a positive answer, else you'll get a negative answer, implying that 'a' points the other way round.
Thanks for the explanation. I will remember to leave ma alone until the problem is fully simplified as much as possible. Also as Joshmdmd said since gravity and the direction of motion are in the same direction, it makes sense that it would be mg-T=ma. Take care.
Joe
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
