Crush1986
- 205
- 10
Substitute \psi = Ne^{-ax^2} into the position-space energy eigenvalue equation and determine the value of the constant a that makes this function an eigenfunction. What is the corresponding energy eigenvalue?
\frac{-\hbar^2}{2m} \frac{\partial^2}{\partial x^2} \langle x | E \rangle + \frac{1}{2} m \omega^2 x^2 \langle x| E \rangle = E \langle x | E \rangle
So, initially I tried to solve for a by plugging in \psi but I got a nasty quadratic \frac{2 \hbar^2 x^2}{m} a^2 - \frac{\hbar^2}{m} a + \left( E - \frac{1}{2} m \omega^2 x^2 \right) = 0that didn't really seem right. I then did some research and found a similar problem where the book stopped at a similar quadratic equation (the problem was for the first excited state) and said that "the x^2 terms must cancel.
Why is that? I guess I haven't seen the energy eigenstates depend on x before... So I suppose that gives reason to believe that the terms with x will negate each other?
Following that recipe I arrived at the same value of a as they do a = \frac{m \omega}{2 \hbar} and I also arrive at the expected energy (Since this given psi is of the form of the ground state harmonic oscillator) E = \frac{\hbar \omega}{2}.
Thanks for any help with understanding this deeper.
