C/C++ Why does my program using cstring work while the one from the book doesn't?
  • Thread starter Thread starter yungman
    C++
The discussion centers on a C++ programming issue where a program using a string literal fails to throw an exception correctly due to type mismatch. The original code throws a string literal, which is of type `const char*`, but the catch block expects a `char*`, leading to a runtime error. A modified version using a character array (`char Cr[]`) successfully throws and catches the exception. Participants suggest changing the catch statement to `catch (const char *e)` to resolve the issue, highlighting the importance of understanding const correctness in C++. The conversation also touches on frustrations with the instructional quality of the book being used, prompting a switch to a different C++ resource.
yungman
I followed the program from the book and it doesn't work. I simplified to show what's going on. I solve the problem and show in the second program. It's the good old cstring and the string literal again.
This is from the book, it doesn't work:
C++:
#include <iostream>
using namespace std;
int main() {
    try
        throw "Alan";//throw a string literal as in the book
    catch (char *e)
        cout << "An exception occurred. Exception Nr. " << e << '\n';
    return 0;
The error is:
I experimented and made it work, this is my program:
C++:
int main() {
    try
    {    char Cr[] = "Alan";
        throw Cr;//Using cstring works.
    catch (char* e)
    return 0;
Only difference is I throw a cstring Cr that contain "Alan". It works.
This is my first day on this, I have no idea why the one in the book doesn't work and why it has to be like what I did to make it work.
Please help explain this.
Thanks
Technology news on Phys.org
I haven't worked with exceptions myself, except to play with them a little when I was learning C++, but...
Remember, string literals are type const char*. I suggest changing the catch statement in your first version to catch (const char *e).
IIRC we were "caught" by this in a different situation in the last few months. I think more recent versions of C++ are stricter about const than when Gaddis wrote his book.
[added] Aha, here it is, back in September:
https://www.physicsforums.com/threads/mysterious-error.993493/#post-6391433
Likes Jarvis323
Now I've had a chance to experiment with your code. With my compiler, both versions (without and with const) compile.
When I run the first version (without const), I get a runtime error message:
terminating with uncaught exception of type char const*
When I run the second version (with const), I get the output that you provided:
An exception occurred. Exception Nr. Alan
So the problem in the first version is indeed the mismatch in types. Your exception handler (the catch block) expects to receive an exception of type char *. You threw an exception of type const char * (a literal string), which "fell through" without being caught.
I'll try adding a second catch block that expects to receive a const char *:
C++:
#include <iostream>
int main() {
    try
    catch (char *e)
        cout << "A char*  exception occurred. Exception Nr. " << e << '\n';
    catch (const char *e2)
        cout << "A const char*  exception occurred. Exception Nr. "
             << e2 << '\n';
    return 0;
The compiler gives me a warning:
warning: exception of type 'const char *' will be caught by earlier handler [-Wexceptions]
note: for type 'char *'
Nevertheless, it runs and produces the output generated by the second catch block:
A const char* exception occurred. Exception Nr. Alan
Next, I tried throwing a char* array as in your second version:
C++:
#include <iostream>
int main() {
    char Cr[]  = "Alan";
    try
        throw Cr;
    catch (char *e)
             << e2 << '\n';
    return 0;
I got the same compiler warning, and when I ran it, I got the output from the first catch block:
A char* exception occurred. Exception Nr. Alan
Summary: The type of the object that you throw determines which catch block receives it. If it doesn't match any catch block, it "falls through" and generates a run-time error.
Likes harborsparrow, Jarvis323 and jedishrfu
Thanks so much Jtbell.
Yes, just adding const made it work. I am developing a phobia with the word const! This word tripped me more than anything else in C++.
Gaddis book is getting worst. I read through the paragraphs many times:
It never explain "exceptionString" in the book. I looked up on line and guess it out. It is argument of the throw statement. I even type "exceptionString in C++" on line, went around in circles thinking it was a function or special word in C++. After reading some examples, then I guess it's just a name of strings and it's whatever argument of the throw.
The book is getting worst in the later chapters and is starting to hinder me in learning.
Thank you so much. I have to read your second post. I just want to reply to acknowledge you first.
Thanks
  • Haha
Likes harborsparrow
jedishrfu said:
Pretty soon @yungman you’ll be writing the book.
The book is really getting worst by the chapter. You can read the page I copied, no where it said what is exceptionString is. I really thought it's a special function and went search up and down. It was until I read cplusplus( I think) used just "e". Then I started to realize it's just meant taking the argument from throw statement and use it in catch! I went back and read the book over, still I do not see anywhere taking about this.
Chapter 15 on Polymorphism was almost as bad, I went through the problems like 10 pages and still don't have any idea what it's for until people here explained it. I went back and read it later after I understood it, still it's not clear in the book.
I am starting to use The book by Ivor Horton and Peter Van Weert right now to read through it.
I wouldn't hold my breath.
  • Haha
Likes jedishrfu
Don't worry, not interested. This is just an exercise for my brain, definitely don't have to passion for it. I don't even want to try to write a book in electronics which I am qualify and have the passion for it. For what? This is just a passing stage like music and photography. I got good, became pro and just dropped it. This is what is fun in life. I already starting to look at the next adventure, it's just not very easy to find one that is challenging and fun. Been into car fixing, gun smithing, cooking, those are just not challenging enough.
  • Love
Likes fluidistic and jedishrfu
Just the first 3 pages of the book by Ivor is a lot clearer:
Likes harborsparrow and jedishrfu
It's not a good idea to throw and catch pointers, partly due to the const/non-const issue you have observed. You can avoid the whole mess as follows.
C++:
#include <iostream>
#include <stdexcept>
int main() {
    try
        // runtime_error can be constructed from a C-style string or a std::string
        throw std::runtime_error("Alan");
    catch (const std::runtime_error& e) // works equally well without const, but I'm not modifying e, so I specify const
        // e.what() gives you the string with which e was constructed
        std::cout << "An exception occurred. Exception Nr. " << e.what() << '\n';
    return 0;
Likes harborsparrow, Jarvis323 and yungman
C++:
#include <iostream>
int main() {
    try
    return 0;
Thanks
But I have not learn runtime_error and e.what(). Must be later in the chapter.
Thanks
I am starting to switch to Ivor book. I have been busy taking the book apart by chapters to make it easier to read, not having to carry the big book around. I have neck problem, I cannot sit and read, have to lie down and keep moving. So I take the book apart and stable each section together, each of about 30 pages. Here is a picture of the few I did today:
Funny, I have two of the Ivor book. I bought the first one from Amazon, it got lost. After a week or so, they sent me a new book. Then 2 or 3 weeks later, the original book arrived. So I ended up have two. So I can take one apart. Actually the second book is under my laptop to prop it up to make it easier for my neck.
One thing good of Gaddis 6th edition, cplusplus actually posted the pdf file of the brief version. I printed the whole book out and stapled into small section to study. I don't have the pdf for the long book and the Ivor, so I have to take the book apart into small sections like in the picture.
Likes fluidistic
@yungman - I'm curious to know how you chose these books instead of C++ Primer by Lippman, Lajoie, and Moo. That's the one I would generally recommend for learning C++.
Likes yungman
Likes harborsparrow and jbunniii
jbunniii said:
That link is to the 4th edition which only covers C++98. There is a 5th edition, which expands coverage to C++11 (a very different language in a lot of ways!) https://www.amazon.com/dp/0321714113/?tag=pfamazon01-20
But the 4th edition is very good if you don't care about learning the C++11 features (yet).
Thanks, I just want to learn C++, I have no plan to be expert nor looking for a job. I think it's good enough already.
Thanks
Likes jbunniii
I have been spending time with the Ivor book. I see some problems with their drawings. I want to run by you guys. The writing makes good sense, it's the diagrams. This is what I modify according to the write up.
Let's look at the first page. I red lined it said the exception object is COPIED FIRST. Then in green lined, all the local objects in the try block are DELETED. Copy has to come first then delete. Look at the fig.15.2, I have to modify the drawing to reflect the sequence. Also, block 3 has to go to the FIRST CATCH, not the Nth catch in the drawing.
Now, look at the next page. Read the line that exception thrown by fun3() passes BACK to fun1(). The diagram is just wrong. I have to modify the diagram.
I am taking back what I said about the Ivor book, the description is very good so far as you can see, it makes the whole world of sense, but the drawing are bad. Wasted me a lot of time going through just this two pages.
Tell me what you think. This is very very important, I want to confirm with you guys before I mark up the book.
Thanks
  • Haha
Likes harborsparrow
I went ahead and wrote down the notes as I understand from the Ivor book regarding to the last post. I hope I am right in the exception handling process:
Nobody have any comment?
I am in big trouble, recall in post 12, I cut the book into small section, stabled and read individually for my neck problem? I somehow put them with the dirty cloths and ran dumped into the washer and started washing! By the time I realized and took it out, they are quite ruined. I am drying them out, meaning I have nothing to read. I might have to buy another used book just to cut it apart as I don't have pdf file that I can print it out.
What a disaster.
Back to the question in post 17 about whether the throw follows the path back from fun3() back to fun1() back to try, or the throw go straight from fun3() to catch. I wrote the program and step through it with f11.
C++:
#include<iostream>
void fun2(int b)
{//go to line 5
    if (b > 2) throw 20;//go straight to line 21
void fun1(int a)
{//go to line 9
    fun2(a);//jump to line 4
int main()
{    int x;
    cout << " Enter an integer between 0 to 2: "; cin >> x;//enter 5
    try//go to line 17
        fun1(x);//go to line line 8
        cout << " You entered: " << x << "\n\n";
    catch(int e)
    {cout << " Out of range.\n\n";}//go to line 22
    cout << " Program ends.\n\n";//go to line 23
    return 0;//go to line 24
I put in comments where the line jump to next.
I entered 5 which is out of range. The program will go to fun1() line 9. Then jump to line 4 then line 5. Since I entered 5, I triggered a throw and jump straight to line 21.
It does NOT go back to fun1() and back to try before going to catch. It jump straight from fun2() throw straight to catch, BYPASSING fun1() and try block.
Can I conclude the writing in Ivor book is wrong and the diagram is correct?
Thanks
Patient: Doc it hurts when I do this.
Doctor: Well, then don't do that.
We can't police what goes on between you and your washing machine.
  • Haha
Likes Jarvis323, Vanadium 50 and yungman
Ha ha!
But isn't it important to know how the program flows? Ivor book have problem. I spent half a day reading and looking at the drawings, only one of them can be right. I think my program shows the drawings is right and the description in the book is wrong. I read it over over 10 times.
You can see in the second page, I red lined it said passing onto the calling function. My stepping show it doesn't.
To paraphrase @Mark44,
No wonder you have trouble with washing machines...
  • Haha
Likes yungman and sysprog
@yungman Do you you have a scanner? Maybe if you're going to take books apart you could scan the pages before putting them at risk? Then if something happens maybe you could resort to the scans?
What does the computer do?
What I described in post 20, I traced through every step where the program jump from line to line.
I am sure it jump directly from line 5 straight to line 21 in catch. I have experience stepping VS, if it goes back to the calling function, it ALWAYS go back to the calling function before exit.
It bypass fun1() and try and jump straight to catch block.Isn't this very important to know? Gaddis say nothing about this at all.
thanks
yungman said:
Ha ha!
It looks like the book is correct.
Here is some code you can use to verify.
C:
#include<iostream>
struct A
    ~A() {
        cout << "destroying A" << endl;
struct E
    E() {}
    E( const E & other ) {
        cout << "copy constructor E" << endl;
void fun2( int b )
    if (b > 2) throw E();
void fun1(int a)
    fun2(a);
int main()
    int x = 5;
    try
        A a;
        fun1( x );
        cout << "You entered: " << x << "\n\n";
    catch( E e )
        cout << "Out of range.\n\n";
    cout << "Program ends.\n\n";
    return 0;
The output shows that the automatic objects in the try block (A a) are destroyed before the exception is copied to the argument of the catch block.
destroying A
copy constructor E
Out of range.
Program ends.
Likes sysprog
Why do you think it should? Throw goes to catch. It doesn't mean "try, try again".
  • Haha
Likes Jarvis323 and sysprog
C:
destroying A
copy constructor E
Out of range.
Program ends.
Thanks Jtbell
I ran your program step by step and label where the line jump to the next line. You can follow where the program goes. It NEVER return from fun2() back to fun1() and return back to try. That is exactly like what my program did. That's the whole point of my post 17. Here is your program with the steps added in comment:
C++:
#include<iostream>
struct A
    ~A() {
        cout << "destroying A" << endl;// to 8
    }//to 40
struct E
    E() {}//to 21
    E(const E& other) {
        cout << "copy constructor E" << endl;// to 16
    }// to 7
void fun2(int b)//Never return back to fun1()
{//to 21
    if (b > 2) throw E();//to 13  to 15
void fun1(int a)
{//to 25
    fun2(a);//to 20
int main()
    int x = 5;// to 34
    try
        A a;//to 35
        fun1(x);//to 24
    catch (E e)
        cout << "Out of range.\n\n";// to 41
    }// to 43
    cout << "Program ends.\n\n";// to 45
    return 0;
Thanks
If you look at post 17, the right side page I labeled "Pass back to func1". You see the book twice said the throw pass back to the calling function.
Yes, My stepping program in post 20 proofed it just go directly from throw in fun2() straight to catch. I am challenge the book. You can see Figure 15.3 is correct that it bypass fun1() and jump straight to catch. The description in the book and fig.15.3 does NOT match.
Thanks
  • #31
Regarding the code in post #20, this is what happens after you enter a number such as 3.
  1. fun1() is called in the try block.
  2. fun1() calls fun2().
  3. Since the argument is larger than 2, it throws 20.
  4. Control is transferred to the catch block, where it prints "Out of range."
  5. Control then goes to the next line, which prints "Program ends."
  6. main() then returns.
Likes yungman
  • #32
Yes, after I posted in post 17 and wasting my time on it, I decided this morning just write a program to proof in in post 20, it's exactly like what you layout here, it doesn't back track like the page in Ivor book page in post 17.
It doesn't matter how the program goes, it's more to find out whether I can trust the Ivor book. I read through it many times and I red line the sentences that support my assertion that the writing in the book does NOT match up to the drawings of the book. You can take a look at post 17.
thanks
  • #33
yungman said:
Thanks Jtbell
C++:
#include<iostream>
struct A
    ~A() {
    }//to 40
struct E
    E() {}//to 21
    E(const E& other) {
    }// to 7
{//to 21
void fun1(int a)
{//to 25
    fun2(a);//to 20
int main()
    int x = 5;// to 34
    try
        A a;//to 35
        fun1(x);//to 24
    catch (E e)
    }// to 43
    return 0;
Thanks
This was about the things you claimed were wrong on the left side of the image you posted. The other thing you thought was wrong (from the right side of the image), I didn't follow exactly. I think you confused what the author was saying/showing.
  • #34
Oh, I have not even get to the left side yet. Let me go through that and get back to you. My book is still drying, it's not as if I have better things to do! :(
Read through the right side, I read it like 20 times. See whether I am wrong or not.
  • #35
I think the diagram is just a confusing diagram because of the clutter.
It says "Normal return" at the end of fun1(){} with an arrow that goes to after fun1(); is called. That means if an exception is NOT thrown, it goes there. The other arrow, says exception can be handled here, points directly from fun1() throw to the catch block.
This is the same as your program shows and as the book says, it's just easy to misread the diagram.
  • #36
Here is a somewhat cleaner version of the same diagram. Light blue is showing what happens if an exception is NOT thrown (normal return). I think in the book they could have left those arrows out, since it's more or less obvious. The red arrows show what happens when the exceptions are thrown.
I think you misread the blue arrows as if they are red arrows?
But yes, the diagram is pretty terrible (correct but terrible), so I don't blame you if you want to find a new book.
  • #37
I am saying the diagram on the right is correct, it's the writing on the page is incorrect.
  • #38
On the image you seemed to indicate it was wrong.
The writing is correct too I think. Maybe it's also just confusing language? What did you think was wrong about it exactly? Anyways, the writing was trying to explain what is shown in the diagram I posted. So if you understand that, you've got it and can move on. If the book you're using is too confusing, then maybe move on and try C++ primer.
  • #39
This is a larger copy and I put red lines. I wrote how I read it. The diagram is correct as proven already, the writing is wrong.
It said the throw is not caught in fun3() ( because fun3() doesn't have a catch block), it will pass to the calling function fun1() ( also don't have a catch block) and should pass back to the one that called fun1() which is the Try block.
From fig.15.3 and both your program and my program, it jumped directly from fun2()( I called fun2() as fun3() in Fig.15.3) to the catch block.
I work with VS enough, if the function passes back to fun1(), it will step from fun3() to fun1() for sure. It did not.
  • #40
It said the throw is not caught in fun3() ( because fun3() doesn't not have a catch block), it will pass to the calling function fun1() ( also don't have a catch block) and should pass back to the one that called fun1() which is the Try block.
Yeah, you just didn't understand. It IS CORRECT! LOL
  • #41
Like how? That's how I read it. Tell me how you read it.
  • #42
yungman said:
Like how?
It isn't saying how the control flow goes. It is explaining the propagation of the exception. Imagine the exception is like a baseball and it is flying past the next lines of code (which aren't being executed) yet, waiting to be caught. It is saying the ball does't just hit a wall at the end of a function, it keeps flying forward until eventually it is caught (then the control flow will go there where it is caught), or if nothing catches it, then program will terminate. The exception propagating doesn't mean the code it is skipping is executing.
Likes Vanadium 50
  • #43
Jarvis323 said:
It isn't saying how the control flow goes. It is explaining the propagation of the exception. Imagine the exception is like a baseball and it is flying past the next lines of code (which aren't being executed yet, waiting to be caught). It is saying the ball does just hit a wall at the end of a function, it keeps flying forward until eventually it is caught (then the control flow will go there), or if nothing catches it, then program will terminate.
No it said it will pass back to the calling function. Like I said, I step through a lot of programs, if it pass through, VS will stop at the calling function even if it stop at the line with the last "}". VS do this every time. It never skip that.
If the book said it will go directly to the catch, then I have no problem with it.
  • #44
yungman said:
No it said it will pass back to the calling function. Like I said, I step through a lot of programs, if it pass through, VS will stop at the calling program even if it stop a the line with the last "}". VS do this every time. It never skip that.
You just didn't understand it. There's nothing at all more to it than that.
  • #45
Sorry, I disagree. Like I said, I stepped through a lot of programs that call functions, even the function doesn't return anything, it will step back to the calling function after it finished.
  • #46
You still obviously don't understand what it was attempting to convey. You can try reading it again, and read my comments, and if you still cannot understand it, just accept you don't get it, and try learning some other way.
  • #47
Jarvis323 said:
You still obviously don't understand what it was attempting to convey. What more is there to say. You can try reading it again, and read my comments, and if you still cannot understand, just accept you don't get it, and try learning some other way.
"An exception that is thrown but not caught within a function may be passed on to the calling function the next level up". This means if the exception is not caught in fun3(), it will passed on to the calling function fun1().
"Exception thrown by fun3() when it is called by fun1(). There is no try block in fun1(), so exceptions thrown by fun3() will be passed to the function that called fun1()." This means exactly what I said above. fun1() doesn't have a catch block either, so the exception is passed from fun1() back to try block.
Tell me which part do I not understand, please enlighten me.
  • #48
Which part do I not understand, please enlighten me.
You're not understanding what the book was trying to explain. You're conflating the author's explanation of the propagation of the exception, with control flow.
Likes Vanadium 50
  • #49
Well agree to disagree. I am very exact as this is science.
This is actually like break, where you drop everything and just jump to the destination.
  • #50
Maybe you can email the author and ask what he meant, and accuse him of making an error, and argue with him about if he is wrong or if you are wrong? I'm just trying to help.
