Question on speed and velocity
  • Thread starter Thread starter koshal303
    Speed Velocity
To determine the depth of the well, the total time of 4 seconds is divided into two parts: T1, the time for the stone to fall, and T2, the time for the sound to travel back up. The velocity of sound is given as 350 m/s. By using the equation for distance (depth = velocity × time), the depth can be calculated by solving the equations for T1 and T2. The discussion encourages further questions for clarification on the problem-solving approach.
koshal303
a stone is dropped in a well is heard to hit the water after 4 sec what will be the depth of the well if the velocity of sound is 350m/s ?
3. the time taken by stone to reach the water surface is T1 and the time taken by the sound to reach out is T2 now T1+T2 = 4 sec.
thats all i could do
You only need to change 3.5 s in the other question with 4.0 s in your task :)
You are welcome to ask if you wonder how I did something there...
