Rotating multiple objects around an axle?
The discussion centers on rotating multiple blocks around a single axle, with the goal of individually positioning each block to one of four sides using a single motor. Key considerations include the number and dimensions of the blocks, the spacing between them, and the feasibility of placing the drive mechanism behind the blocks. Suggestions include using a large diameter tubular axle to allow for internal gears in each block that engage with a pinion on a shaft inside the axle. The motor's engagement with the appropriate shaft is noted as a separate challenge. Overall, the focus is on finding a simple and efficient method for achieving this rotation.
Codester09
I'm looking for a way to rotate blocks. There is a single axle going through the blocks.. say there are a dozen of them. I am trying to figure out a way to rotate each block individually to one of the 4 sides based on different inputs. I am also trying to accomplish this with a single motor if possible. Can anyone tell me the most simple/efficient way to accomplish such a task?
Thanks in advance!
How many blocks will there be and what will their approximate dimensions be?
How much gap is there between the adjacent block's side faces?
Can the drive mechanism be placed behind the blocks, say on a parallel shaft?
Does rotating the block do work or is it balanced?
Is there room inside the blocks for a large diameter tubular axle?
That could provide access to drive the blocks through holes in the axle wall. Each block might have an internal gear that engages with a pinion on a long shaft inside the axle. Those shafts would be arranged around the inside circumference of the axle. The motor would then be engage with the appropriate shaft, but that is another problem.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
