Second Law of Thermodynamics - heat pumps and air conditioners
The discussion revolves around calculating the effective coefficient of performance (COP) for a heat pump functioning as an air conditioner, with a COP at 35% of the Carnot efficiency. The user initially converted the heat removal rate from Btu to joules and attempted to calculate the ideal COP using the provided temperature values, arriving at 1.05, which they doubted was correct. They then multiplied this value by 0.35 but received an incorrect result for part a of their homework. The conversation seeks clarification on the proper method to determine the effective COP and the power required for the compressor motor. Accurate calculations and understanding of thermodynamic principles are essential for resolving these queries.
elcaptain
A heat pump operates as an air conditioner, drawing 20000 Btu per hr from a building. It is operating between 21 degrees Celsius and 41 degrees Celsius.
a) If the COP (coefficient of performance) is 35% that of a Carnot air conditioner, what is the value of the effective COP (coefficient of performance)?
b) What is the value of the power (Watts) required for the compressor motor?
QL = heat removed from the low temperature area (inside the building)
QH = heat removed from the high temperature area (outside the building)
W = work done to remove the heat
TL = temperature of system at lower temperature (inside the building)
TH = temperature of system at higher temperature (outside the building)
COP = QL/W
COP = QL/(QH - QL)
COPideal = TL / (TH - TL)
I first converted Btu (British thermal unit) to joules: 1Btu = 1055.056 J. Then I tried finding the ideal COP by using the above equation with the given temperatures and got 1.05, but I'm pretty sure the ideal COP is not calculated this way. I tried multiplying 1.05 by 0.35 but got the wrong answer for part a. Thanks for any help.
anything?
A Full Stack Development Program prepares students to create end to end web applications using front end as well as back-end technologies. The purpose is to get experience in creating user interfaces, managing databases, and conducting server-side activities, resulting in a thorough understanding of how web platforms work. This skill is essential since it allows developers to participate at every step of a project, enhancing critical thinking and productivity. registering in Full Stack...
