Sound Frequency & Pipe Wall Thickness
The discussion centers around the relationship between the wall thickness of open metal tubes and the frequency of sound they produce. Participants explore the effects of wall thickness on sound frequency, considering both theoretical and practical implications, including potential applications in musical instruments like pipe organs.
  • One participant notes that the tube with a thicker wall (2.0mm) produces a higher frequency than expected, suggesting that the reduced volume of air inside may influence this outcome.
  • Another participant argues that the mass of the thicker wall should reduce the frequency, while the elasticity of the metal may increase it, indicating a complex interplay between these factors.
  • A later reply mentions the importance of finding an expression for the resonant frequency to determine which effect is dominant.
  • One participant expresses confusion over the results, affirming that their understanding was that a thicker wall would lower the frequency, yet the opposite is observed.
  • Another participant introduces a finite element method (FEM) modal analysis, suggesting that the deformation mode for sound may not be bending but rather related to wall deformation, with stiffness being a significant factor in determining frequency.
  • It is proposed that in the context of a pipe organ, the sound is primarily produced by moving air rather than the pipes themselves, implying that wall thickness may not have the same influence in that scenario.
Participants express differing views on the relationship between wall thickness and frequency, with no consensus reached. Some argue that mass and elasticity have competing effects, while others suggest that the specific conditions of the tubes may lead to unexpected results.
Participants mention the need for additional information regarding the materials and potential variations in manufacturing processes, such as heat treatment, which could affect the results. There is also a lack of clarity on the exact mechanisms at play in the observed frequency differences.
Daimion
TL;DR
Why, when striking an open tube, a thicker walled tube produces a higher frequency than a thinner walled tube?
We have 2 open metal tubes, made of Stainless Steel. They both are the same length of 1 metre, and and Outer Diameter of 76mm. One pipe has a wall thickness of 1.5mm, and the other has a wall thickness of 2.0mm.
It was our reasonable guess that the tube with 2.0mm wall thickness, should producing a lower frequency. However, when we strike it, it actually produces a higher frequency than the one with 1.5mm wall thickness.
Why is that?
One consideration we had - since they both had the same Outer Diameter, the volume of air inside the tube with a thicker wall is less, and affects the frequency somehow to make it higher?
An extended question, would this "thicker wall = higher frequency" pattern have the same effect in a pipe organ? The difference that the frequency is produced by the moving air vs the vibration of the tube walls.
Thanks! Really hoping to understand wall thickness vs frequency effect better.
[Edit] I've taken a video to show clearly the sound difference between the two pipes, if that helps.
Welcome to PF.
There are two things happening.
Firstly; the mass of the thicker wall tube will reduce the frequency.
Secondly; the elasticity of the metal will produce a greater restoring force from the thicker wall tube, that will raise the frequency.
You must find an expression for the resonant frequency of the tube to identify which effect will be the greater.
I would want to know if the stainless steel alloy used to make the tubes was identical.
There is also a possibility that a different heat treatment, or the age of the tubes, causes a difference to the restoring force.
Baluncore said:
Welcome to PF.
Thanks for help, and yes, my understanding was that the thicker wall should reduce the frequency, yet it seems the reverse. As for materials, both pipes are made the same and from 304 stainless steel.
I've captured it on video, both with the pipes standing upright on the floor, and laid on my bed sideways (so it is open at both end).
When standing on the floor, the tube on the right is 2mm thick, and the tube on the left is 1.5mm
When laying down, the tube on the left is 2mm thick, and the tube on the right is 1.5mm
Video unavailable
This video is private
Baluncore said:
Video unavailable
My mistake, have made it viewable now
There was someone that posted a question about tube resonances and why the thick walled tube had a higher frequency. But it is gone?!? Anyway, I'm stubborn (and actually put some effort in the answer), so here is my answer anyway:
Question:
A tube with outer diameter of 76mm and length of 1m is hit, why does the tube with wall 2mm have a higher frequency than the one with 1.5mm diameter. How does this relate to a pipe organ.I've done a very quick FEM modal analysis. I think the deformation mode for sound is not a bending motion but rather something like below, where the wall of the pipe is deformed. In the solution below the 2mm wall has a significantly higher eigenfrequency than the 1.5mm thick wall. So stiffness wins from mass in this case.
Also, a pipe in a pipe organ is a helmholtz resonator. This is all air that is moving, not the pipes themselves. This means that thickness should not have an influence there.
1.5mm thick:
2mm thick:
  • · Replies 31 ·
