Surface integral, spherical coordinates, earth
The discussion focuses on calculating the surface area of the Earth above 50 degrees latitude North using spherical coordinates. The initial integral setup was incorrect, leading to an erroneous result of 0.321 instead of the correct value of 0.117. The correct approach involves adjusting the limits of the integral for the polar angle θ, which should range from 0 to 40 degrees. This adjustment is crucial for accurately determining the surface area fraction.
  • Spherical coordinates and their applications in surface integrals
  • Understanding of the determinant of the metric tensor in differential geometry
  • Knowledge of integral calculus, specifically double integrals
  • Familiarity with trigonometric functions and their properties
  • Study the derivation of surface area formulas in spherical coordinates
  • Learn about the determinant of the metric tensor in the context of surface integrals
  • Explore the concept of latitude and its relation to spherical polar coordinates
  • Practice solving surface integrals with varying limits of integration
Students in mathematics or physics, particularly those studying calculus and differential geometry, as well as educators looking for examples of surface area calculations in spherical coordinates.
HmBe
Find the surface area of the Earth (as a fraction of the total surface of the earth) that lies above 50 degrees latitude North.
$$A = \int_R\sqrt{|\det(g)|}d\theta d\phi$$
Hence I get
$$\int_0^{360} \int_{50}^{90} r^2 \sin(\theta) d\theta d\phi$$
Which gives 0.321 as the answer, which just isn't right. The actual answer I know should be 0.117, or
$$\frac{1-\sin(50)}{2}$$
I'm sure something must be wrong with my integral, but I can't figure out what.
Hence I get
In the northern hemisphere, the spherical polar coordinate [itex]\theta[/itex] is equal to [itex]90^{\circ}[/itex] minus the latitude. Thus the correct limits of the [itex]\theta[/itex] integral are 0 and [itex]40^{\circ}[/itex].
You're a hero, I have mental problems. Thank you so much.
