Ideal Gas Law: Encyclopaedic Experimental Data
The discussion highlights that the ideal gas law becomes more accurate in low-density conditions, such as higher vacuums. It questions whether there are experimental data contradicting this trend and seeks theoretical explanations for it. The ideal gas law is derived from statistical mechanics, treating gas molecules as point particles without volume or interactions, which limits its applicability in high-density scenarios. An ideal gas is not equivalent to a vacuum, as a vacuum implies the absence of gas, while the ideal gas is a theoretical construct. Overall, the ideal gas law is a useful model but has limitations in real-world applications.
Prokop
The “ideal gas” law
The well-known, encyclopaedic experimental data (about gas compressability factor) show the general trend:
the more rarefied gas the more accurate “ideal gas” law,
or the same in other terms:
the higher vacuum the more accurate “ideal gas” law.
1) Are another experimental data which contradict the trend ?
2) Are the theory which explains the trend ? (Classic or quantum molecular-kinetic theories do not considered as absolutely unsuitable).
3) Does your conclude the so called “ideal gas” is namely vacuum ?
I'm not sure if I understand your questions correctly, but I'll have a go at answering them:
1) I don't know but I don't think so.
2) The ideal gas law is a law derived from statistical mechanics. It treats the gas molecules as point particles, with no volume. It also assumes the particles do not 'feel' each other in any way except that they bounce elastically with each other and the walls.
Now imagine if you have a LOT of particles, they will take up a lot of space. But in the ideal gas law model, they won't take up any space at all since they are all point particles! Clearly the law will not work very well there.
If you have very little particles however, the little volume they take up will not be so important and the ideal gas law will work much better.
3) An ideal gas is not a vacuum, since a (perfect) vacuum means actually no gas at all (this cannot exist in reality). An ideal gas does not exist, it is merely a theoretical model of a gas.
