Thermal Expansion in Liquids and Steel
The discussion revolves around the topic of thermal expansion in liquids and solids, specifically comparing the volume expansion of oil and a pot made of steel. The original poster attempts to apply the formulas for linear and volume expansion to determine the temperature at which the oil bubbles over.
  • Exploratory, Assumption checking
  • The original poster describes using volume expansion equations and expresses uncertainty about equalizing the volume changes of the oil and pot. Some participants question the assumption that both materials expand equally in volume.
Participants are actively engaging with the problem, with some suggesting adjustments to the original approach. There is recognition of the need to reconsider the relationship between the volumes of the oil and the pot, but no consensus has been reached on a definitive solution.
The original poster indicates that the final temperature calculated seems incorrect, suggesting a misunderstanding in the setup of the problem. There is also mention of a specific numerical difference in volume that may affect the outcome.
kgm01
The coefficient of linear expansion of steel is 11 x 10-6 K-1 and the and the coefficient of volume expansion of a certain cooking oil is 0.92 x 10-3 K-1. A steel cooking pot is 90% filled with this cooking oil, both at 24 oC. If the pot and oil are both slowly and uniformly heated, the temperature at which the oil will start to spill out of the pot is closest to:
A 50 oC
B 75 oC
C 100 oC
D 150 oC
E 200 oC
∆L=αLi∆T
∆V=βVi∆T
β=3α
This is a repost as I didn't read the community guidelines the first time. Hopefully this is better!
First thing I did was write down both the linear and volume expansion formulas.
I then multiplied my alpha by 3 and used the volume expansion equation for both materials.
∆V oil > ∆V pot, at the point where the oil bubbles over.
I used volumes of 0.9 for the oil and 1 for the pot and made the equations equal to each other as the ∆V would be the same at the point where it bubbled over.
In doing this, I got a final temperature of 24ºC which is clearly incorrect as the final temperature must be higher than the initial.
I have a feeling that my mistake was made in equalising the ∆V but I'm not too sure. Have been attempting this problem in different ways but can't seem to get the right answer.
The correct answer is D
Thanks!
Right. If both the oil and the pot increase their volume by the same amount, then the oil will still have less volume than the pot.
Ohh true. So if I did ∆V oil > ∆V pot + 0.1 (difference) I would get the correct answer. Thank you!
Yes. Good.
  • · Replies 67 ·
  • · Replies 16 ·
